Gas Thermal Expansion
Posted 07 August 2009 - 06:58 AM
I am designing a PSV to protect piping and a Jacketed pipe exchanger that heats gas. The PSV will be located on the cold outlet piping.
Gas being in the pipe (cold side) and is high pressure than jacketed side, the most probable case for this is Thermal expansion of gas.
I have calculated relief temperature using an expression of ideal gas law:
Tr = Pr * (T/P)
where,
P = Operating Pressure
T = Temperature
Pr = Relief Pressure
Tr = Relief Temperature
And calculated the relief flow using Q = m x Cp x (Tr-T)
where
Q= Normal exchanger heat duty
m=Relief flow
Cp=specific heat at relieving conditions.
Main thing is I need confirmation whether i can use this or is there any other method to calculate relief rate.
Thanks in advance.
Posted 12 August 2009 - 11:10 PM
I request you to please give the comments on this topic.
Thanks in advance,
Pavan.
Posted 13 August 2009 - 09:53 AM
The actual heat input will decrease from the moment the scenario first occurs until the cold side temperature reaches that of the hot side. The PSV will start to relieve when the cold side temperature has increased sufficiently to cause the pressure to reach the set point of the PSV. From that point, the temperature will continue to rise as the cold side T approaches the hot side T, and the resulting rate of heat transfer (and required relief flow) will decrease accordingly.
You could use the ideal gas law to calculate the number of moles in the cold side initially (P1,V1,T1) and then do calculate the amount at the final condition (the point where the cold side reaches the temp of the hot side). The rate of heat transfer tell you how long it takes to get from the first state to the second, therfore that allows you to calculate a required relief flow.
Posted 14 August 2009 - 06:27 AM
Posted 14 August 2009 - 10:59 AM
kpavan,
I understood your configuration as
- Jacketed pipe exchanger.
- Gas is cold fluid in pipe
- Heating medium (i.e. hot water, hot gas, hot oil...) in jacket.
Gas in pipe being trapped while heating medium in jacket flowing continuously. Heat from heating medium transfers to gas in pipe, heated gas caused pressure increase upto PSV set pressure, PSV open and subsequently PSV relief. This is typical blocked-in-heat-on.
For BIHO, higher the heat input or heat flux, higher the relief load. Thus, relief load is subject to heat input or heat flux.
The equation that you mentioned is typical applicable to gas (or supercritical fluid) filled vessel expose to pool fire (as discussed in API Std 521 section 5.15.2.2.2). This equation may only applicable to heat input due to pool fire (with specific heat flux).
What you need to do is to find the gas expansion rate base on heat flux, find PSV relief load from gas expansion rate by keeping gas pressure in pipe constant at 110% of set pressure (if 10% overpressure is allowed by design code).
Posted 18 August 2009 - 05:12 AM
Thanks for reply.
As described by Joe Wong, my calculation are almost like that of fire case in gas filled vessel. Because in fire case for gas, it is thermal expansion with some exceptions while taking relieving temperature and heat flux calculations. But here i have taken the design heat flux of exchanger as constant and used it further for calculating relieving capacity based on the relieving temperature as posted in the question i have earlier asked.
Joe Wong,The equation that you mentioned is typical applicable to gas (or supercritical fluid) filled vessel expose to pool fire (as discussed in API Std 521 section 5.15.2.2.2). This equation may only applicable to heat input due to pool fire (with specific heat flux).
May i know which edition of API 521 you are describing, Because i am having 1999 edition in it fire case is described in 3.15.2.1.2 and i didnot find any section you have described, if there is anything different in that section please let me know.
Fallah,
My model is similar to that of Gas filled vessel in fire case.
Lowflo,
Initially I tried the way you described, but calculations seemed to be a little confusing. So, I switched over to this kind of calculation to make it simple.
Pls. give me some more suggestions/comments.
Pavan.
Posted 18 August 2009 - 09:22 AM
Dear all,
Thanks for reply.
You may have different heat flux... Stick to constant UA could be easier for you.
Joe Wong,
Latest release : API Std 521, 2007 edition with addendum May 2008.
Edited by JoeWong, 19 August 2009 - 09:38 AM.
Posted 18 August 2009 - 11:07 PM
[/quote]
dear mr.wong,
from where one can get this latest edition of API Std 521?
![]() Fire Case Gas Expansion (Gas Filled & No Liquid)Started by Guest_moosa.akbar_* , 27 Aug 2024 |
![]() Thermal FuseStarted by Guest_Dr_bigfoot_* , 09 Apr 2024 |
Coefficient Of Conversion Of Electrical Energy Into Thermal Energy ForStarted by Guest_amx_* , 03 Apr 2024 |
![]() Butane Thermal Expansion By Sun Radiation In PipeStarted by Guest_fedi.abdeljawed_* , 10 Jan 2023 |
