Aspen Plus Error Message
Posted 13 August 2009 - 06:55 PM
I am getting the following error message while trying to simulate the chlor alkali case in aspen plus. Any input on this would be of great help.
Thanks,
green
->Processing input specifications ...
* WARNING IN PHYSICAL PROPERTY SYSTEM
PARAMETER MW/ELEMENT 1 (DATA SET 1)
LOWER BOUND VIOLATED FOR COMPONENT E-
VALUE = 0.55000E-03, LOWER BOUND = 1.0000
PARAMETER TRUEMW/ELEMENT 1 (DATA SET 1)
PARAMETER PLXANT (DATA SET 1) FOR COMPONENT NAOH:
UNREASONABLE VAPOR PRESSURE CALCULATED AT NORMAL BOILING POINT.
VALUE SHOULD BE WITHIN 10% OF 1D5 N/SQM. PLEASE CHECK YOUR INPUT
FOR THE ANTOINE PARAMETERS.
*** SEVERE ERROR
ERROR COMPILING IN-LINE FORTRAN
COMPILER MESSAGES FOLLOW ...
C:\PROGRA~1\ASPENT~1\APRSYS~1.1\Engine\xeq\gcpp.exe -DWIN32 -DAWINNTN -D__INTE
ASPCOMP: Warning! Intel Fortran compiler ifort.exe not found in %PATH%
ASPCOMP: Warning! Microsoft C runtime library msvcrt.lib not found in %LIB%
ASPCOMP: Warning! Microsoft C runtime library is needed for Dynamic Linking.
ASPCOMP: Warning! Intel Fortran runtime library libifcoremd.lib not found in %
ASPCOMP: Warning! Intel Fortran runtime library is needed for Dynamic Linking.
ifort.exe /nologo /c /Qsave /iface:cvf /MD "-object:_4525cgr.obj" "_452
*** SEVERE ERROR
COULD NOT RESOLVE USER OR IN-LINE FORTRAN SUBROUTINE(S):
SUBROUTINE "E" IS MISSING
*** SEVERE ERROR
SUBROUTINE "W" IS MISSING
*** SEVERE ERROR
PROGRAM TERMINATED DUE TO UNRESOLVED ROUTINES
! Errors while processing input specifications
Posted 28 August 2010 - 08:30 PM
Hi all ,
Thanks,
green
*** SEVERE ERROR
*** SEVERE ERROR
*** SEVERE ERROR
*** SEVERE ERROR
You must have install intel visual fortran compiler and that also require microsoft visual studio to install on your machine
Aspen Hysys - Creating A New Component And Defining PropertiesStarted by Guest_catiiiii_* , 22 Apr 2024 |
How To Find K-Values Of A Hydrocarbon Mixture On Aspen Hysys?Started by Guest_Alexis Azamar_* , 08 Apr 2024 |
Olga And Aspen Simulation SoftwareStarted by Guest_CHEMSTRONG_* , 27 Mar 2024 |
Answered
Centrifugal Compressor Performance Curves In Aspen HysesStarted by Guest_Rafcio_* , 14 Mar 2024 |
Aspen Custom Model Won't Load Into HysysStarted by Guest_SaintLazarus_* , 21 Mar 2024 |
