hi guys,
does anyone have literature about the IBR CODE regarding psv sizing for different scenario?
if anyone have it,please let me know.
Ibr Code
Started by thakur, Aug 19 2009 05:04 AM
Posted 19 August 2009 - 05:04 AM
Posted 21 August 2009 - 05:31 AM
hi guys,
Dear,
IBR code is for Boilers, which also describes the safety measures for boilers.
You have to find the relieving capacity for different scenarios as per you would do for normal cases, and find the Area requied by using below equations.
For saturated steam, as per Equation 78 of IBR-293
E=C*A*P,
where E is rated discharge capacity of saturated steam (kg/hr),
P is the relieving pressure (bar a),
A is the orifice area of safety valve(mm2)
C is a constant which changes as per lift.
Type of valve -- Value of C
Ordinary lift -- 0.05
High lift -- 0.10
Full lift -- 0.24
For superheated steam, as per Eqn. 79 of IBR-293
Es = E/(sqrt(1+2.7 Ts)/10000)
where Es is rated discharge capacity of superheated steam (kg/hr)
Ts is the degree of superheat, deg C.
Hope this helps
Regard,
Pavan
Asme Code For Fiberglass Pressure Tank FeaStarted by Guest_Pheeto_* , 13 Feb 2024 |
Ll Extraction: Equilibrium Stages Calculation With Matlab CodeStarted by Guest_MGFX70_* , 14 Apr 2022 |
Asme Code For Low Temperatur Lpg PipelineStarted by Guest_Butterfly_* , 21 Jan 2021 |
Utility Piping Design Code In CanadaStarted by Guest_wenchop_* , 16 Jan 2019 |
Ei Model Code Of Safe Practice Part 15: Area Classification For InstalStarted by Guest_usama.iqbal_* , 10 Dec 2018 |
