Dear all,
I want to calculate Brake Horse Power from Hydraulic Horse Power.
Branan Rule of Thumb state the equation for pump efficiency but range applicability is 100 ~ 1000 GPM.
It also state that 25~ 30 GPM pump efficiency is below 10.
My concern is when the flow rate is 8 GPM, how to estimate this efficiency?
Any literature for this?
Thanks in advanve before..
Pump Efficiency
Started by demank, Aug 21 2009 01:07 AM
Posted 21 August 2009 - 01:07 AM
Posted 01 September 2009 - 03:38 AM
Hallo,
I just calculationg that equation and graph.
And found that graph give a 500 rpm with efficiency about 20%.
Then my next question. 20% efficiency is not good.
Any pump vendor that have a single stage centrifugal pump which can deliver liquid about 8 gpm and head 90 ft?
(with pump efficiency above 50% of course)
Posted 04 September 2009 - 01:24 PM
Be Practical.
Always go with a lower efficiency during intial design since you tend to overdesign your electrical system a bit. The efficiency values could be verified after you get a firm quote from the vendor.
In your case, the BHP is either 1 for 20 % efficiency and 0.4 with 50 % efficiency. Figure it out, which one you will choose.
ARAZA
ARAZA
