I'm just revising for a heat transfer test this afternoon. I think the nerves may be getting the better of me as I can't seem to answer the following, which should be a simple heat flow question
The wall of an oven is made from steel sheets with 50 mm mineral insulation between them. The internal temperature in the oven is 300°C and the room air temperature is 15°C. The thermal resistance of the steel sheets can be neglected.
Data
Film heat transfer coefficient of the hot air inside the oven: 15 W/ m2 °C
Film heat transfer coefficient of the air outside the oven: 15 W/ m2 °C
Thermal conductivity of mineral insulation: 0.08 W/ m °C
Calculate the heat flow through the oven wall (W/ m2).
I believe that the only way you can figure it out is to apply the basic heat flow equation;
q = (-k*A*deltaT)/x
where;
k =0.08 W/mC
A = we can assume it to be 1 m2
deltaT = (300-25) = 285 C
x = 0.05 m
Although my lecturer's answer is 376 W/m2 , mine is 456 W/m2 , however the lecturer is certain his answer is correct.
Any advice PLEASE?
Kel
Heat Flow Through Oven Wall!
Started by , Aug 27 2009 06:16 PM
Posted 27 August 2009 - 06:16 PM
Posted 27 August 2009 - 07:09 PM
You should calculate base on convective heat transfer.
In this case natural convection.
For example,
Churchill and Chu [Int. J. Heat Mass Transfer, 18, 1323 (1975)] recommend, for laminar flow on isothermal vertical wall follow equation: (Perry 8-05, page 5-8)
For example,
Edited by demank, 27 August 2009 - 07:10 PM.
Posted 27 August 2009 - 08:41 PM
kelly ,
Transfert from inside the oven (air) by convection then trough the wall by conduction and then to outside .
Q=U*A*Dt with U global heat transfer coefficient , I guess you know how to calculate U
Teg Dehydration Stripping Gas Flow RateStarted by Guest_SidRah_* , 20 Aug 2025 |
