Pump Vapor Lock
#1 bobbobs
bobbobs
  • 17 posts
Posted 28 August 2009 - 01:00 PM
I was reading through the different relieving scenarios for a relief valve that was done by another engineer and came across the term vapor lock in reference to pumps. The scenario had a vapor stream exiting the vessel, entering a condenser that used cooling water, and then entering the pumps. One case was that cooling water was lost causing vapor lock to the pumps therefore leading to a blocked discharge. What exactly does vapor lock mean? Thanks!
#2 Root
Root
  • 293 posts
Posted 28 August 2009 - 01:43 PM
Hi
Vapour dose not allow liquid to enter in the suction of pump and neither come out from pump, in an other words these vapour remain in circulation.
#3 bobbobs
bobbobs
  • 17 posts
Posted 28 August 2009 - 02:02 PM
Toor,
So once vapor enters that pump then it is just circulating within the pump not allowing anything to either enter or leave? How is the problem remedied? Thanks for the help!
Edited by bobbobs, 28 August 2009 - 02:03 PM.
#4 breizh
  • 6,939 posts
Posted 29 August 2009 - 02:13 AM
Bobobs
Need to stop the pump and replace the gas with liquid ( refer to start up procedure SOP).
