Relief To Blowdown Drum Before Flare Stack
Posted 21 September 2009 - 08:26 PM
From what I have read, blowdown drum is used to prevent vented chemicals, possibly toxic, from being released into the atmosphere.
Posted 25 September 2009 - 06:01 PM
You may find it informative to read these two articles in the online encyclopedia Citizendium:
Posted 28 September 2009 - 03:06 AM
What is the purpose of relieving to a blowdown drum first before being vent to the flare stack?
Dear mbeychok,
Thanks for your reply.
Let me clarify my question. In my company, relief is sent to the blowdown drum, and then to a KO drum, before sending it to the flare.
My question is why do they need 2 vapor-liquid separators one after another? Is there a safety issue involved here?
Posted 28 September 2009 - 01:02 PM
The purpose of second KO drum which installed as close the flare stack as possible,is eliminating any liquid accompany the gas may be formed due to condensation of gaseous hydroicarbons moving along usual considerable distance between first KO drum inside the plant and second KO drum outside plant's battery limit.My question is why do they need 2 vapor-liquid separators one after another? Is there a safety issue involved here?
Posted 29 September 2009 - 01:06 PM
Posted 15 October 2009 - 03:35 AM
Another reason may be that the blowdown drum is there to remove any large quantities or "slugs" of liquid which might overload the following vapor-liquid knockout drum.
Also if the flare stack is high and especially if vertical the 2nd vessel catches any condensed liquids that flow back from mid way between flare tip/base
