Steam Pressure Of Reboiler
Posted 26 September 2009 - 10:15 AM
Please i need your help.
Thank you
Posted 27 September 2009 - 10:37 AM
Steam control valve acts as a "pressure modulating" valve - adjusting condensing pressure based on cold/process fluid boiling temperature requirements.
Posted 27 September 2009 - 10:44 AM
Steam pressure inside the reboiler will not change as long as you keep the tower pressure constant. The best way to look into steam reboilers is that they are actually steam condensers. Steam condensation temperature is driven by the cold process fluid temperature, and furthermore the steam condensation temperature determines the steam condensation (reboiler) pressure.
i was asked to change the steam pressure from 10psig to 12 psig by adjusting the steam control valve, and need to determine its effect, i found out that the temperature of the bottom trays are going up and the top trays stays the same plus the overall efficiency going up. remeber every thing is at totall reflux.
also the reflux temp goes up.
can you tell me why i see this changes?
Posted 27 September 2009 - 12:39 PM
By opening the steam control valve:
1. The pressure downstream of the valve increases
2. Condensation temperature increases
3. Heat input increases (UAdT)
4. More vapors flow up the tower
5. The condenser load increases and the overhead receiver runs hotter (hotter reflux)
6. Since it is a total reflux system, now more liquid is cascaded down the tower
7. Trays work with higher vapor/liquid loads and therefore reach higher efficiencies, if flooding limit is not exceeded.
Posted 27 September 2009 - 12:59 PM
If you raise the pressure in the reboiler by opening the steam valve you increase the condensing temperature of the steam and provide more driving force for getting heat into the column. This means you have a higher boil up and higher traffic in the column. This higher traffic will increase the pressure drop across the trays (or packing) and therefore you should see the base pressure rise. This increase in pressure raises the boiling point of the liquid in the base and it is quite normal to see the base temperature rise in response to increased steam flow to the reboiler (and vice versa).
This higher boil up will result in more reflux in the column (you said you are on total reflux). This will result in a sharper separation in the column and it is possible that there is a zone that now has more of the top (low boiling) product than it had before. In a way you can think of the high boiler being "pushed" down the column. This could lower the temperature of that zone.
The top pressure should not change materially because it is only affected by the pressure drop through the condenser and this is usually low (or the top pressure is controlled at a particular value). So the top temperature will only be affected by the top composition. If the top purity does not change then the top temperature will also not change.
Ideally your reflux should be at the condensing temperature. If your reflux temperature has increased this can only mean that previously the reflux was being subcooled. The increased boil up results in less sub-cooling capacity in the condenser and the reflux temperature rises (but never above the condensing temperature). The situation at the top of the column is a bit ambiguous because in your first post you said the condenser temperature rises, but in your second post you said the top temperatures remain the same. This is contradictory, unless by "condenser temperature" you are referring to the water side. The water side would get hotter because it has to remove more heat.
So there you have some explanations to justify your observations, but remember that there are many other things that could affect the situation as well.
Posted 27 September 2009 - 01:04 PM
Posted 27 September 2009 - 06:43 PM
Actually your post was much more 'engineering' and complete than my answer. Thanks for elaborating on the subject.
Posted 27 September 2009 - 11:25 PM
Harvey,
Thank you all, it was very helpfull
Flow & Pressure Regulation For Compressible FluidsStarted by Guest_Abdessamed1961_* , 14 Dec 2025 |
Steam Drum SizingStarted by Guest_nastaran_* , 01 Dec 2025 |
