Is there any suitable formula for calculating the velocity of a compressible fluid that exits the pore of the perforated pipe distributor?
Given the pressure drop across the bore, mass flow rate, bore diameter.
Thank you
Perforated Pipe Distributor
Started by conan_kaya, Oct 05 2009 02:01 AM
No replies to this topic
Posted 05 October 2009 - 02:01 AM
Flow Through A Perforated PlateStarted by Guest_Ahmadhamzahperta_* , 13 Feb 2026 |
Gas-Liquid Pipe Flow Friction Loss CorrectionStarted by Guest_Huba_* , 18 Dec 2025 |
Software For Calculating Flow Through A PipeStarted by Guest_Deep24_* , 07 May 2018 |
Velocity In A Vertical Pipe Or Open PipeStarted by Guest_jango_* , 02 Dec 2025 |
Pipe Segment In Hysys Not SolvingStarted by Guest_Frya_R_* , 20 Jul 2025 |
