Npsh And Viscosity On Pumps
Posted 08 October 2009 - 07:00 AM
For viscos liquid we consider correction factor for flow, head and pump efficiency, But for viscos liquids NPSH®, is required to be considered????.
For higher/lower specific gravity liquids any correction factor is to be considered for NPSH®.
Question No 2: For screw pumps / Progressive cavity pumps /Gear pumps
Increase in Viscosity in the pumped medium will “improve”/ “have no change in” the pump performance for positive displacement pumps????. If so, the viscosity correction factor chart can be totally neglected for positive displacement pumps??
Whether NPSH® is equally important for positive displacement pumps like centrifugal pumps??
Posted 08 October 2009 - 07:58 AM
NPSHR is the pressure differential required to enter pump impeller eye for avoiding vapor bubbling. It needs correction for viscosity because more viscous liquid needs more pressure differential to enter pump impeller eye. It does not need correction for specific gravity because NPSHR is defined in the unit of length (feet or meter) that eliminate the impact of specific gravity. The same rules should be applied to the positive displacement pumps.Question No 1: In the centrifugal pump performance curve NPSHr indicated by the pump manufacturer is for water (sp.Gr = 1.0 and viscosity = 1Centipoise ).
Posted 08 October 2009 - 08:12 AM
![]() Centrifugal PumpsStarted by Guest_panoska_* , 01 Feb 2025 |
Negative Sign In Newton's Law Of Viscosity?Started by Guest_Cheeky_* , 24 Oct 2024 |
![]() Selection Of Type Of Pumps For "negative" Npsha And Solution TStarted by Guest_linda_pro_* , 29 May 2024 |
Vibration Of The Pump (Reciprocating Pumps / Plunger Pumps)Started by Guest_vsedhuraman_* , 06 Oct 2023 |
Viscosity CalibrationStarted by Guest_waheed2020_* , 11 Dec 2022 |
