Nitrogen Purge Gas
Started by hpe, Oct 11 2009 05:34 AM
Posted 11 October 2009 - 05:34 AM
dear all
how can I calculate, rate of nitrogen purge gas for sulphur recovery unit?
what is the purity of nitrogen gas for this use?
with regard
with regard
Posted 15 October 2009 - 03:11 AM
dear all
with regard
You will have to be a little more specific.
Purity of nitrogen in a purge gas is not important as long as the impurity is inert (normal impurities in commercial nitrogen are helium and other gases found in trace amounts in air) if you are using nitrogen from a generator then the oxygen content is important and should certainly not be above 5% under any circumstances.
Posted 17 October 2009 - 04:48 AM
hi VikingUk
dear all
with regard
thanks for your reply.
in a sulphur recovery plant,nitrogen is using for snuffing of sulphur burning in catalyst bed when the unit is out of service. then oxegen content is very important parameters & 5% is very high for our purpose.
Posted 19 October 2009 - 05:06 AM
hi VikingUk
[/quote]
Exactly...!! But you still do not give enough information to enable anyone to help you.
[/quote]
Posted 19 October 2009 - 08:47 AM
[quote name='VikingUK' date='19 October 2009 - 05:06 AM' timestamp='1255947375' post='33478']
hi VikingUk
[/quote]
[/quote]
when sulfur recovery unit is shut down , even with very low amount of air ,pirophoric material & sulphur burn & operators detect high temp at catalyst bed , in our plant we use snuffing steam at this time.but have another problem . it is CORROSION. then we decided to get a nitrogen plant. I need a general advice about rate of nitrogen & purity of nitrogen for this use.
thanks
hi VikingUk
[/quote]
[/quote]
thanks
Posted 19 October 2009 - 11:48 PM
we have both LP steam and N2 line in a same reactor. N2 is supplied from our N2 generation plant.5% O2 in N2 is very high, it will not extinguish fire , rather to ignite more. Flow rate will depend on the Reactor size. You should follow the specific NFPA codesand standard.
For our CBA process I can give you the N2 supply presure( 6 Barg) and reactor size/ catalysts volume / line size etc., after .
Regards.
Regards.
Nitrogen Capacity Tankfarm During WinterStarted by Guest_jango_* , 03 Feb 2025 |
![]() Nitrogen Leak Test On PipeStarted by Guest_mesbah_* , 24 Oct 2024 |
![]() Most Feasible And Economically Friendly Nitrogen Supply For Tank BlankStarted by Guest_Godwin Anyimah_* , 27 Sep 2024 |
![]() Using Feed Compressor For Start-Up Nitrogen CirculationStarted by Guest_behrouzifar_* , 06 Sep 2024 |
Nitrogen RequirementStarted by Guest_Ali4269278331_* , 05 Jun 2024 |
