I have been working on a project to resurrect a BD plant. The plant uses waste vegetable oil as feedstock. This is reacted with excess methanol in the presence of catalysts to produce the FAME.
I have been working on the methanol recovery of the whole process and thus far have accumulated a lot of questions. Any help would be appreciated? I have no access to simulation softwares so all my calculations thus far have been by hand.
1. Should I be worrying about methanol loss during the trans esterification reaction if the reactor is open to the atmosphere via a vent duct and the space between the max liquid level and the top of the reactor (start of vent) is 3 ft.
2. After production, flash recovery is used to recover some of the methanol from the glycerol and BD streams, any calculations or specific equations I should be looking at? (I've seen a lot but too many variables)
3. Anybody have access to a simulator to investigate optimum pressure and temperature for the flash tank (vessel).
Methanol Recovery In Biodiesel Plant
Started by A.N.T., Oct 18 2009 06:52 PM
No replies to this topic
Posted 18 October 2009 - 06:52 PM
Sulfuric Acid Plant Aspen Hysys HelpStarted by Guest_kazuki222_* , 29 Apr 2026 |
Lpg Plant DesignStarted by Guest_betulche_* , 08 Mar 2026 |
Air Separation Plant DesignStarted by Guest_adda_* , 03 Mar 2026 |
