Piping
Posted 19 October 2009 - 08:14 PM
Could anyone tell me if there are guidelines available or suggest rules of thumb for the piping lengths from the top of the column to the condenser, reflux drum and back into the column. And also the same for the reboiler. Also what types of valves should be considered. Any feed back would be great.
Thanks.
Posted 20 October 2009 - 10:50 PM
Then, the line size of OVHD line will be considered. The following criteria is an example for line sizing around the column.
For Overhead Line Guidelines:
(deltaP/100’)MAX = 0.070 P^1/2 psi
vMAX =100 / v^1/2 (fps) – not to exceed 60-80 fps
where P’ = pressure at the overhead receiver, psia
where v = density of vapor at flowing temperature and pressure, lb/ft3
For columns operating at very low pressure where minimum pressure drop is critical, use the following guideline:
(P/100’)MAX = 0.035 P^1/2 psi
For Bottom Line to reboiler:
(P/100’)MAX = (0.0062) (l – v) - 0.06 (psi)
where l = density of liquid at bottom of column, lb/ft3
v = density of vapor in reboiler return line, lb/ft3
For reboiler return line
Kettle Type Reboiler: (deltaP/100’)MAX = 0.20 psi
Thermosyphon (or once-through, non-pumped): (deltaP/100’)MAX = (0.0062) (l - v) - 0.016 (psi)
where l = density of liquid in return line to column, lb/ft3
v = density of vapor in return line to column, lb/ft3
However, the location of them should be considered about its level too.
Posted 21 October 2009 - 02:06 AM
Vapour lines: The important thing is the pressure in the column, not the pressure drop in the line. Set your pipe pressure drop to suit the pressure range you need in the column.
Condensate lines: I have seen these lines cause problems where the velocity is too high and vapour (or even air) is drawn down the pipe. This affects instrument readings and air in the column is obviously not a good thing. The section of pipe above the reflux nozzle should (in my opinion) be designed to be self venting. Kister discusses this in detail.
In general reboiler piping is kept short and no valves are used. But I have used a reactor to reboil a column and the two units were about 15 metres apart, so this rule is not unbreakable. But it did take some trial and error to get the piping right.
Posted 21 October 2009 - 04:05 PM
i think the condensor and reboiler should be located near the column as much as possible due to pressure drop minimization.
Maximum Velocity For Piping In Fire Water Distribution System (Fire WaStarted by Guest_applepe_* , 06 Sep 2024 |
Pressure Drop In PipingStarted by Guest_Jaldhipatel_* , 05 Jun 2022 |
![]() Pressure Loss In Piping - Cooling Tower-Shelltube HeatexchangerStarted by Guest_Alneto_* , 29 May 2024 |
Piping Design_ Pump PipelineStarted by Guest_anh.phungthai@boydensvn_* , 29 Feb 2024 |
Two-Phase Flow Piping DesignStarted by Guest_Vegeta_* , 09 Dec 2022 |
