Does someone know how to determine the volumetric displacement and the DP of a helical screw (mixer, extruder, pump...) based on the geometric dimensions (angle, length, diameter, thread depth...) and the rpm ?
Weickert (Ind.Eng.Ch.Res. 1998,37,799-806) did provide the eqns but for a hollow shaft type of screw.
Thanks for your help,
Vinh
Design Of Screw Mixer
Started by Guest_Vinh_*, Nov 10 2004 01:40 PM
No replies to this topic
Guest_Vinh_*
Posted 10 November 2004 - 01:40 PM
![]() Scrubber DesignStarted by Guest_nasss_* , 07 Aug 2024 |
![]() Heat Exchanger Network DesignStarted by Guest_Kakashi-01_* , 21 Feb 2025 |
Screw Compressor Suction Pressure DeterminationStarted by Guest_Deicide Dunkelheit_* , 22 Jan 2025 |
