Hydrate Inhibitor Rates
Posted 21 October 2009 - 09:06 AM
I've been using X = dM/Ki+dM
where
d = °C depression of hydrate point (we use an extra safety margin of 5 °C on this value so d = Hydrate Formation Temp. - Min. Op. Temp. + 5
x = weight percent of inhibitor in the liquid water phase
M = mol weight of inhibitor
Ki = constant ( 2220 for glycol)
Taken from Campbell’s “Gas Conditioning and Processing – Volume 1, The Basic Principles
But I'm not sure if I should be allowing for how water wet the gas is (about 350ppmv)as there is no water phase in a gas line
Posted 22 October 2009 - 10:23 AM
Does anyone have any advice on calculating how much MEG I should inject in a gas flowline to inhibit hydrate formation ?
where
Sure, it is a fancy formula. When we need chemical inject rate information, we always relay on the chemical provider's advice. The methanol/water ratio is between 1:3 and 1:6 depending on gas pressure to prevent hydrate formation. If LDHI is used, the ratio is something like 1/42.
Posted 23 October 2009 - 06:00 AM
Hi Viking
No i don't think you need to allow for the gas water content. THe MEG solution that is injected as hydrate inhibitor is likely be 50 to 70 % MEG and the rest water. This is how you determine your value for X.
If you have access to HYSYS you could try cross checking the results of your hand calculations against the HYSYS hydrate formation utility. The Utility will predict the hydrate formation conditions for you gas stream. You can then add a mixer and introduce a stream of say 60% MEG 40% water (by weight)to your gas stream. You then enable the hydrate inhibitor calculation within the utility and adjust the flowrate of your MEG solution to see what the effect on the hydrate formation temperature is.
Posted 11 February 2010 - 05:16 PM
where
Posted 11 February 2010 - 05:22 PM
![]() Gas Hydrate Inhibition: Calculations For Meg/methanol InjectionStarted by Guest_PYG_* , 30 Sep 2019 |
Hydrate Formation Using Aspen HysysStarted by Guest_Hamza Almansouri_* , 10 Mar 2022 |
Pro Ii - Adjusting Std Flow RatesStarted by Guest_lsoaresfernandes_* , 26 Oct 2021 |
Hydrate Formation During DepressurizingStarted by Guest_Ghasem.Bashiri_* , 11 Aug 2021 |
Hydrate Formation (Upstream Or Downstream Pressure)Started by Guest_rs20170808@gmail.com_* , 04 Jul 2021 |
