Two Phase Flow Map
Guest_Mayuri_*
Posted 21 October 2009 - 01:42 PM
Does anyone know if there is a program or software that can identify the two phase flow pattern give flow rates, velocities, etc?
Thanks!
Posted 22 October 2009 - 04:36 AM
Thanks!
HYSYS pipe segments allows you to select from a number of two-phase flow correlations. They include flow maps that estimate the flow regime for the pipe segment and calculate phase velocities. The pipe segment operation breaks down the pipe into increments and will allow you to investigate flow regime and phase velocity profiles along the length of your pipe. The Beggs and Brill 2-phase flow correlation is a popular method and is the default correlation HYSYS uses. But other correlations and flow maps are available including the Aziz, Govier & Fogarasi and the Gregory Aziz Mandhane flow maps which are the ones presented in the GPSA handbook.
Posted 22 October 2009 - 07:34 AM
You may easily develop an Excel program to identify two phase flow regime per the attached Mandhane Regime Map.Hi,
Thanks!
Guest_Mayuri_*
Posted 22 October 2009 - 01:06 PM
Thanks!
Thank you!
Guest_Mayuri_*
Posted 22 October 2009 - 01:08 PM
Thanks!
Thank you!
Posted 08 February 2012 - 10:08 AM
Thanks!
Where is the attachment?
Posted 09 February 2012 - 11:49 PM
Three Phase Seperator ModificationStarted by Guest_halkeshhulk_* , 10 Jun 2025 |
![]() Flow Through Normally No Flow LineStarted by Guest_iippure_* , 08 Apr 2025 |
