Reducing Steam Pressure
Posted 01 November 2009 - 05:41 PM
I am new to this forum, was wondering if someone could answer my question below
At present I have a scenario where steam is being reduced from 8 to 5.4 bar and is metered as tonnes used in that area per week. Will I use less tonnage of steam if I was reducing pressure from say 10 bar to 5.4 bar?
CLEO
Posted 01 November 2009 - 08:20 PM
Posted 01 November 2009 - 10:09 PM
Dear all,
CLEO
Dear Cleo
My understanding is that you may save some steam since the specific enthalpy of steam at higher pressure is higher. A rough estimate shows that if you are currently consuming 1000 kg/h of 8 barG steam, by changing to 10 barG steam you may require about 997 kg/h steam. So some saving could be realized. You may estimate the saving by heat balance or if you have simulation software (such as HYSIS) you may run that simulation.
Posted 04 November 2009 - 11:13 AM
Dear all,
CLEO
Yes, but you would have to put more energy in to increase the pressure from 8 bar to 10 bar so your total savings would be nil.
Posted 04 November 2009 - 03:23 PM
Everybody agrees 1 ton of 10 bar saturated steam contains more heat duty than 1 ton of 8 bar saturated steam. However, steam consumption is counted as “ton/hr” not “btu/hr”.Dear all,
CLEO
Therefore, 1 ton of 5.4 bar steam letdown from 10 bar saturated steam is equivalent 1 ton of 5.4 bar steam letdown steam from 8 bar saturated, although the steam letdown from 10 bar is hotter. You should not expect people pay you more for the hotter steam just as nobody will pay extra energy cost for an over burned Big Mac. Higher steam temperature may result product degradation or faster equipment fouling.
The story will be different, If you have a desuperheater after letdown valve. 10 bar saturated steam will evaporate more BFW and produce more ton of 5.4 bar saturated steam than 8 bar saturated steam will.
Pressure BuildupStarted by Guest_Yankee_* , 31 Mar 2026 |
Spray Dryer Nozzle Issue – Pressure Increase And Fines IncreaseStarted by Guest_Ella2365_* , 24 Mar 2026 |
Steam Carrying Liquid From The Sour Water Stripping TowerStarted by Guest_kaidlut_* , 12 Sep 2024 |
