Conversion Of Ppm Gas To Ppm Liquid
Posted 03 November 2009 - 09:59 AM
I cannot understand where this 31.5 conversion factor is coming from, can anyone please enlighten me?
Thanks in advance.
Posted 03 November 2009 - 10:41 AM
My first thought is that it represents the Vapor-Liquid Equilibrium(VLE: specifically K-value) of DCM over rest of the solvent. Except for pure DCM and an azeotropic mixture with DCM, one would expect the concentration of DCM in the gas phase to be different from the concentration of DCM in the liquid phase. Could that be what you are seeing?We are looking at our IR sampling device on site and have noticed that there is a conversion factor of 31.5 from our PPM reading of the gas phase (collected via tubing from the deadspace of a pipe) to give us our PPM value in the liquid phase.
Thanks in advance.
Posted 04 November 2009 - 07:52 AM
Thanks in advance.
That would seem like a very reasonable explanation, I sort of thought it might be that but was unsure if it possibly had anything to do with a constant that was relelvant to the specific dimensions of the pipe the sample was taken from or some other physical property. Thanks for your help!
Pressurizing LiquidStarted by Guest_Ahmadhamzahperta_* , 02 Apr 2025 |
Modeling Liquid-Liquid Membranes In Aspen PlusStarted by Guest_bodinjas_* , 18 Mar 2025 |
