Mccabe Smith Unit Operations
Started by rana680, Nov 13 2009 06:42 AM
Posted 13 November 2009 - 06:42 AM
anyone having solutions to mccabe smith unit operations ??? plz send it to rahulrana681@yahoo.co.in
Posted 18 November 2009 - 09:27 AM
Dear,
What you want from us to solve the unsolved problems and to send those to you?
Posted 19 November 2009 - 11:14 AM
no..just wanted to know if neone is having the solution manual so dat i can use it wen i m not able to solve some particular problem.also mccabe doesnt hv answers to ne of the questions which is a bit frustrating as u cannot find out whether u hv solved da problem correctly or not.
Posted 19 November 2009 - 02:05 PM
rana680,
This here is a chemical engineering forum & not a chat room for 'SMS' language. If you are a chemical engineering student or an engineer then don't disgrace the profession by using this kind of incoherent & inexplicable language. This forum expects coherent english used by professional engineers or engineering students.
Well I can't resist asking you whether you use the same 'SMS' language while submitting your assignments to your professor, if you are a student or a engineering report to your supervisor, if you are already an engineering professional.
![]() Fixed Bed Absorber Tsa UnitStarted by Guest_Sufy_* , 13 Mar 2025 |
![]() ![]() Molecular Sieve UnitStarted by Guest_Sufy_* , 26 Feb 2025 |
Basic Dynamic Simulation Of A Crude Distillation UnitStarted by Guest_tomr91_* , 12 Jan 2025 |
![]() Vacuum Getting Disturbed Periodically In Vacuum UnitStarted by Guest_aka28_* , 08 Oct 2024 |
