Flow Transmitter On Compressor Suction
Posted 27 November 2009 - 06:15 AM
Could anybody can explain me the reason why do we always place the Flow transmitter in the compressor suction. We have placed the flow transmitter in the discharge (For my concern Flow transmitter is just going to measure the flow thats why we have used in the discharge)
Posted 27 November 2009 - 07:23 AM
Of course, the reason for measuring centrifugal compressor flow is to - control and avoid surge conditions that can seriously damage the machine. Usually, just for saving on pressure drop, these flow elements are located on the discharge side for machines having low suction pressure, while for other machines you can use suction side for flow measurement.
Posted 22 December 2009 - 12:24 PM
I think you are talking about a closed loop which the compressor is installed in. If I am not mistaken, the flow is in Nm3/hr, in that case does it make any difference between suction and discharge? Since its normal flow it should be the same.Dear all,
Posted 22 December 2009 - 05:51 PM
Compressor discharge is at higher temperature and flow meter to cope for higher temperature is required at discharge. Flow meter at suction side experience low temperature may be cheaper.
Posted 23 December 2009 - 02:14 PM
It is because the variations in pressures,temperatures and turbulence of the gas are less upstream of the compressor.
Posted 27 December 2009 - 11:31 AM
[quote name='lokesh_09' date='27 November 2009 - 06:15 AM' timestamp='1259321140' post='34501']
[/quote]
For measuring Actual Volumetric flow rate, Flow Transmitter is placed at suction. This is because, at Discharge the N-m3/hr is different from Suction (Volume is reduced due to compression). For controlling surging you can use flow meter at discharge, or between stages (for multi-stages)
Posted 28 December 2009 - 04:42 PM
Parallel Compressor Setup With Uneven CapacitiesStarted by Guest_sinrem_* , Yesterday, 07:09 AM |
![]() Flow Through Normally No Flow LineStarted by Guest_iippure_* , 08 Apr 2025 |
