Please I need explanation on how an oil & gas well can be tested. Reasons for testing the wells & equipments used
Well Testing
Started by Temmy, Dec 03 2009 08:08 AM
Posted 03 December 2009 - 08:08 AM
Posted 15 December 2009 - 11:15 AM
Dear Temmy
I am not Reservoir Engineer but I am trying my best to explain it:
- Well is tested by a test separator and its associated flowmeter. During the test the operator will change the pressure condition such as ramp-up, packing, unpacking etc... to understand the reservoir pressure (not bottom hole pressure) for calibrate their reservoir models (in operation phase) or build reservoir model (in project phase). The fluid composition are then brought onshore to the Lab to run the full test of their composition and other tests regarding chemistry and rheology of fluids.
- The reason for the above tests is to understand your reservoir and its fluids to optimize operation of facilities (in operation phase) or design the right assets(in project phase).
Hope this answer your questions, if you need more explanation, please be specific.
Cheers
Dzum
Cheers
Dzum
Psv Backpressure TestingStarted by Guest_sam1111_* , 17 Mar 2025 |
Performance Testing Of Air Cooled Heat Exchanger In Off Design ConditiStarted by Guest_go-fish_* , 09 Dec 2024 |
Please Support To Sharing The Refer Documents To Prepare Testing &Started by Guest_Vincent.Tran_* , 02 Oct 2021 |
Testing Of 24" Ansi 150# Rating Butterfly ValveStarted by Guest_Instnapp05_* , 23 Apr 2021 |
Compressor TestingStarted by Guest_CHEMSTRONG_* , 18 Aug 2020 |
