Two Liquid Phases Separation In Hysys
Posted 05 December 2009 - 03:31 PM
I want to simulate a liquid-liquid separator by HYSYS. In this separator a stream includes 60wt% Water and 40wt% Furfural (C4H3O-CHO) enters a vessel and get residence time. The Furfural density is about 1.13 kg/lit and goes down and water that is lighter goes up and two liquid phases are separated.
I simulate this separator in HYSYS by a 3-phase separator. I used “Kabadi Danner” as the fluid pakage but I have a problem! The light and heavy liquid phases leave separator reversed! The organic phase (The Furfural rich phase) leaves the separator as light phase and the watery phase leaves as heavy liquid phase!
What’s my mistake?! Please help me…
Posted 06 December 2009 - 10:59 PM
You will separate 2 phase of liquid then try to simulate with 3-phase separator?
I think you should try another vessel for simulation.
Or HYSYS does not support 2-phase of liquid/liquid separation?
Posted 07 December 2009 - 11:35 PM
Please design the vessel as a two phase separator.
Which is the dispersed phase, furfural or water? This you can check easily with a formula given by SM Walas in his book 'Chemical Process Equipment' page no. 613. Based on this result we can discuss further.
Regards.
Posted 08 December 2009 - 10:33 AM
Dear,
Please check with the proper refernce before you quote the above statement.
Posted 08 December 2009 - 10:37 AM
Dear,Dear all
You are modeling the right way.Just want to ask why yor using KD Fluid Package why not any activity coeffiecient model like Uniquac, NRTL. The concern is to check the BIPs for these 2 components in KD fluid package and the densities given by the KD fluid package. Waiting for your comments.
Posted 10 December 2009 - 01:47 PM
It looks like this applies to more than just PR and SRK. Interesting; good observation.The Peng-Robinson and SRK property packages will always force the water rich phase into the heavy liquid phase of a three phase stream. As such, the aqueous phase is always forced out of the bottom of a three phase separator, even if a light liquid phase (hydrocarbon rich) does not exist. Solids are always carried in the second liquid phase.
Posted 15 December 2009 - 04:36 PM
Thanks for your attention and excuse my long delay in reply to your messages. In the previous days I tried to get more information about the Furfural and its usages.
Furfural is a common solvent that used to extract the aromatic components from the feed of the lubricating oil production. In the solvent recovery steps of this process the mixture of Furfural and Water is the overhead product of stripper towers.
Furfural is partial immiscible in Water. Also, its density is about 1.13 kg/lit and is heavier than water. Thus, based on these properties a liquid-liquid separator vessel is used to separate water from furfural. The attachment here is a schematic picture that indicates the vessel and its input and outputs.
This separator consists of a horizontal tank divided into two compartments by a solid baffle. The feed stream enters the first compartment, pass through a calming baffle (perforated baffle) and settle into two phases.
The heavy phase containing about 93wt% Furfural and 7wt% water is trapped in front of the baffle. The lighter phase containing about 10wt% Furfural and 90wt% water flows over the baffle into the second compartment.
I simulated this separator in HYSYS with a 3-phase separator and the concentration of light and heavy liquid phases is approximately correct.
But, so that I told you before, the light and heavy phases leave the separator reversely! The aqueous phase (Water Rich Phase) leaves the separator as Heavy phase and the heavy phase (Furfural Rich Phase) leaves the separator from top position!
I tested other fluid packages such as UNIQUAC or NRTL but this problem don’t solve! Two liquid produced phases leave the separator reversely even when I use other fluid packages.
Sincerely Yours,
Hossein Karimi
Edited by hkarimi, 15 December 2009 - 04:40 PM.
Posted 16 December 2009 - 02:52 AM
Please give us all data like: Flow rate, density, viscosity for both the light and heavy phases at operating conditions, interfacial tension between heavy & light liquid to judge the ease or difficulty of separation and operating temperature and pressure. If you know the droplet size distribution in feed it is better.
Based on the above data I will design a separator for you.
Regards.
Posted 19 December 2009 - 03:43 PM
I'm sorry but I could only get this information.
Furfural rich phase (90wt %) flow rate is 14 cubic meters per hour.
Water rich phase (7wt %) flow rate is 4 Cubic meters per hour.
Operating temperature is 90 degrees centigrade.
Operating Pressure is 0.02 barg.
I think this information isn’t enough for you.
However, many thanks for your attention...
All the best.
#10
Posted 21 March 2012 - 05:07 PM
Did we have an answer for the issue described above? I am facing the same problem with separating out Furfural and Water out using the Separator in Hysys. Thanks for your help
Duane
#11
Posted 25 March 2012 - 10:50 PM
#12
Posted 26 March 2012 - 02:02 AM
A true multiphase flash and a excel page for simulating the liquid liquid separator.
Your simulator should be able to solve this phase equilibria, if not you can consider a suitable process library as Prode Properties , once you have solved the phase equilibria and know composition and properties of different phases it should be easy in Excel to size the separator,
I use the formulations given in "Gas liquid and liquid-liquid separators" by Steward and Arnold and results are reasonably accurate.
I wonder why many engineers do not use Excel for these tasks, well, it's ok to use a simulator for converging streams but then tools as Excel or Matlab are much more flexible for equipment sizing.
#13
Posted 02 April 2012 - 04:22 PM
![]() Teg Regeneration Hysys HelpStarted by Guest_connex_* , 17 Jul 2025 |
![]() ![]() Design Of Direct Contact After Cooler (Dcac) For Air Separation UnitStarted by Guest_Paulogeorge_* , 29 Jul 2025 |
![]() Pipe Segment In Hysys Not SolvingStarted by Guest_Frya_R_* , 20 Jul 2025 |
Isenthalpic Throttling With Flashing LiquidStarted by Guest_lofarcio_* , 06 May 2022 |
