I have a question about crude heaters, what is reason of medium steam connection to crude passes before entering
heater and when it is in service?
regards
Edited by karzan, 09 December 2009 - 03:16 AM.
Posted 09 December 2009 - 03:12 AM
Posted 09 December 2009 - 09:17 AM
Posted 10 December 2009 - 02:58 AM
Posted 12 December 2009 - 09:29 AM
Actually, for Crude oil heaters in ADU the purpose of having MP Steam connection is to provide an option for quenching/cooling heater tubes in case of crude oil flow trip.
Once if the flow of crude oil completely stops (e.g. charge pump failure) the heater will be shut down as well - however the remaining radiant heat can cause overheating of tubes and, in certain occasions, failure of tube elements. MP steam is there to ensure adequate heat removal from the system.
Best regards,
Posted 15 December 2009 - 05:38 PM
Posted 21 December 2009 - 06:12 AM
Hi Dears,
regards
Edited by iyer, 21 December 2009 - 10:52 PM.
Posted 05 January 2010 - 03:04 AM
Hi,Hi Dears,
regards
Posted 27 April 2011 - 11:29 AM
Hi Dears,
regards
![]() Fired Heaters/ Burners/ Flue VelocityStarted by Guest_Lyne_* , 15 Mar 2024 |
Selection Type Of Heater For Refrigerated PropaneStarted by Guest_livetolove003_* , 07 May 2025 |
Electric Heater In Regeneration Absorption BatteryStarted by Guest_alaasleem2026_* , 01 Sep 2024 |
![]() Cross Temperature In Heater Exchanger (Lng)Started by Guest_Yogan_* , 21 Feb 2024 |
Why To Maintain The Skin Temperature At 150Degc In Fired Heater ?Started by Guest_johneyissac98_* , 12 Jan 2023 |
