Thanks for the replies
Should have put a little more information on there. It should be noted that this is an existing design.
The purpose of this existing system is to top up a pond (open to the atmosphere). The purge inlet also comes from another pond which is at atmospheric pressure. The intention of the air inlet line (again at atm pressure) was not as a purge, but to act as an anti-siphon device, thus preventing backflow of liquor back up the purge line (the 150NB line).
As the anti-siphon line is located on the vertical section of pipe, it is envisaged that the pipe may not be fully flooded, having the potential to draw air into the main purge line.
This is where the problem may lie. It has been pointed out that the entrained air may be causing enhanced turbulence at the exit of the purge pipe, thus increasing aerial releases local to the purge exit from the surface of the pond.
I have used the following equation from the htfs handbook (for self venting flow in vertical pipelines):
d > (4M/(0.3*PI*D*(g^0.5)))^0.4, where M is the mass flowrate of water (purge), d is the purge pipe diameter, D is the density of water and g is the gravitational constant. If d is greater than the right hand side of the equation, this minimises the potential for gas entrainment.
In this case, d is not greater than the right hand side of the equation and therefore there is a much greater potential for gas entrainment.
What do you thinkwould be the correct approach for estimating the flow rate of gas/air into the pipe (solving Bernoulli??)?
Mike
Edited by MikeO2, 15 December 2009 - 05:59 AM.
