Fired Heaters
Posted 24 December 2009 - 06:54 AM
any refinery is using two extreme fueld that is natural gas and or hydrogen rich gas from reformer as fuel to heaters. If so, what is their experience of heater performance when fuel is changed from natural gas to hydrogen rich gas and vice versa. regards
Posted 24 December 2009 - 09:07 AM
Read more at:
http://www.engineeri...ases-d_823.html
http://www.engineeri...ndex-d_421.html
http://www.documenta...ation Solutions
http://www.dcgpartne...Wobbe_Index.pdf
Posted 26 December 2009 - 03:11 AM
Well as expectedHi everybody
1. The calorific value or the HHV changes, this changes the requirement needs for providing fuel for the same quantity heat.
2. High hydrogen content in the fuel gas results in greater velocities through the burner tips and hence erosion of these tips. This ultimately results in a bad flame profile due to damaged tips. Better check the burner data sheets.
3. The continuous change calls for a lot of adjustment in operations, hence a bit of a difficulty in heater optimization.
Zauberbergs doucments on Wobbe index are worth a read.
Posted 05 January 2010 - 02:33 AM
Hi everybody
Hi prabha
More volumetric flow will be required for firing hydrogen rich gas and thus will limit the heat duty. In the refinrery I worked with (couple of years ago) we change the burner so as to have the right firing capacity. Perhaps you may consult burner vendor for a dual type of firing. Normally we have dual firing for oil and gas, in your case may be dual firing between heavy and light gases.
Edited by S.AHMAD, 05 January 2010 - 02:34 AM.
Posted 06 January 2010 - 10:48 PM
Hi everybody
Hi prabha
S. Ahmad,
If flame length is hi due to more rich H2 fuel gas then what startegy we can adopt to correct heat duty problem and reduce convection zone tempearture.
awaiting for your reply.
Toor
Guest_Nish_*
Posted 16 January 2010 - 03:24 PM
Hi everybody
Hi prabha
S. Ahmad,
Toor
Hi Friends,
I did one project study on the various modification required while switching ethane based fuel gas system in to more hydrogen rich (70%)lean fuel gas system in a middle east refinery. I hope your heater might be supplied by means of a fuel gas not exclusively for the heater. So I think it is worth sharing the details of my study so that all of us get a good exposure and we could touch all the corners of this.
1. Due to lowering of LHV (i prefer LHV instead of HHV) the volumetric flow rate will be increased, hence the pipe hydraulics has to be validated.
2. The knock drum sizing and its nozzle has to validated.
3. Control valve trim size and flow element has to resize.
4. Burners of almost all the heaters were changed because of NOx and high flame length and to keep short flames the velocity thru the burner kept high (around 40-60 fps)
5. ESD system was validated
6. PSV on the upstream of heater (KOD fire case) was resized.
7. Fired heater efficiency reduction must be evaluated along with a consideration on fouling of exchange surface.
Gents, Let us discuss each cases and omit those not applicable to ur case.
Edited by Nish, 16 January 2010 - 03:26 PM.
![]() Fired Heaters/ Burners/ Flue VelocityStarted by Guest_Lyne_* , 15 Mar 2024 |
Troubleshooting Temperature Overshooting In Convection HeatersStarted by Guest_Alaa55_* , 27 Oct 2024 |
Why To Maintain The Skin Temperature At 150Degc In Fired Heater ?Started by Guest_johneyissac98_* , 12 Jan 2023 |
Electric HeatersStarted by Guest_panoska_* , 24 Sep 2022 |
