Regarding Distillation Column Top And Bottom Height
Started by xzell, Dec 28 2009 01:05 AM
8 replies to this topic
Posted 28 December 2009 - 01:05 AM
Hi guys, im new around here. Recently my lecturer gave me an assignment to size a column, and i need to decide the top liquid disengagement height and the bottom surge height for my column.
i know that the guidelines are bout 4 feet for the top and 6 feet for the bottom. However, my lecturers asked for justifications. I tried finding but to no avail, all of them just cite general figures as rule of thumbs. I'm wondering if anyone here could help me? Thanx
Posted 28 December 2009 - 02:40 AM
xzell ,
Let you read this document and consider the references .
http://www.cbu.edu/~...ll7.html#height
Perry is also a good reference
Hope it helps
Hope it helps
Posted 28 December 2009 - 10:37 AM
xzell ,
Hope it helps
Hi bro, thanx for yr help, unfortunately, i was not able to access the link u gave me. it says access denied
Posted 28 December 2009 - 10:48 AM
Refer to attached materials from GPSA Databook. The bottom sump dimensions (height) will depend on the residence time required for this particular application. Top section details will depend on feed/reflux arrangements so there is no universal answer.
Posted 28 December 2009 - 11:34 AM
If you have single pass trays, then the top height is usually governed by the requirement of a manhole at the top. In that case, you would need a 24 inch manhole and minimum 3.5 ft above the top tray for the manhole.
If you have a more complex arrangement like two or four pass trays, then you may need more than 3.5 ft above the top tray.
Hope this helps,
Abhishek
Hope this helps,
Abhishek
Posted 01 January 2010 - 01:21 AM
hi guys,
Thanks for all your help so far. Maybe I should phrase my questions this way:
Why must we have a liquid hold up at the bottom and a vapor space at the top?
Posted 01 January 2010 - 05:11 AM
Liquid volume is required for two reasons: level control purpose, and provision of static head for reboiler circulation in case of thermosyphons. Different examples are given in the document I have attached in my previous post.
Vapor disengagement is required on top of the tower in order to maintain separation efficiency and avoid intensive liquid entrainment into the equipment downstream.
Posted 01 January 2010 - 12:40 PM
I will add this third reason to Zauberberg's good response:
An amount of liquid inventory is needed at the bottom sump due to the common sense need to create a SEAL between the liquid being evacuated and the vapor phase retained. This is typical engineering good, practical sense.
Think about it. How can one continuously evacuate liquid from the the bottom contents without allowing vapor blow-through? The answer is that you must create a phase barrier; and that phase barrier is a nominal level of liquid (either for thermosyphon reboiler purposes or for simply ensuring that you evacuate only liquid from the bottom sump. If you want to evacuate all liquid from the vessel as soon as it is introduced or formed, leaving only vapor in the vessel, you are trying something that is practically not possible or needed. Why would you seek to do such a thing?
Posted 03 January 2010 - 06:46 AM
Thanx alot for your help, really appreciate it
Hybrid Packed And Tray ColumnStarted by Guest_Zulfise_* , 04 Aug 2025 |
