Electric Resistance Duct Heater
Posted 01 January 2010 - 02:54 PM
Please help me for designing a Electric resistance duct (finned tube)heater to heat air from 85 to 100 C
I need book/study material for complete design. also if anybody have experience in modeling that in HTRI 5.0 would also be helpful( i heard that they include this in HTRI in may 2009, news letter from in this regard is in google )
please help me, I am already running out of time.
Raja
Posted 01 January 2010 - 06:24 PM
You seem to require detailed design. Plant Electrical Engineer or Electricians could specify all the details required (as in the event above), or at least give substantial help.
Hope you will accomplish the task on time.
Edited by kkala, 01 January 2010 - 06:26 PM.
Posted 02 January 2010 - 11:52 PM
I am a freelancer and just started in process design and simulation that's why I really need this type of help . I would be happy if i could help you in future, regarding simulation of process plants
reply
Unfortunately my experience is not enough to help. However I remember an urgent instruction to heat air upstream a bag filter from ~100 0C to 120 0C (to avoid water condensation) in a fertilizer company (1978). As Operators we only calculated the power of the electric resistance (mass airflow*Cp*Δt) and told electricians to install resistance of such kW in the air duct. The work was implemented in about three days, fortunately electricians did not asked for details and no fins were used.
Posted 03 January 2010 - 02:48 AM
Hoping of effective help by others, a few more (even trivial) on the subject (comments welcomed):
1. I was informed that (in case of fertilizer industry) the resistance was placed in a tube (sheath) like a coil, installed in the duct.
2. Fins were not used; but this would increase heat transfer coefficient (per m2 of "bare" tube) to air, hence resulting sheath temperature would be theoretically lower.
3. Process is self regulated to some extent: Heat produced by resistance is passing to the air with variation of sheath and tube temperature (heat capacity of the latter assumed insignificant).
4. Resistance, insulating material in sheath, tube, have a max acceptable temperature (usually advised by Electrical Engineer). A high high sheath temperature cutoff (of electricity) is needed to protect these materials, in addition to other controls.
Edited by kkala, 03 January 2010 - 02:56 AM.
Selection Type Of Heater For Refrigerated PropaneStarted by Guest_livetolove003_* , 07 May 2025 |
Resistance K Of ReducersStarted by Guest_Seonwoo_* , 20 Mar 2025 |
Electric Heater In Regeneration Absorption BatteryStarted by Guest_alaasleem2026_* , 01 Sep 2024 |
Negative Resistance Coeffecient For TeesStarted by Guest_panoska_* , 11 May 2024 |
![]() Cross Temperature In Heater Exchanger (Lng)Started by Guest_Yogan_* , 21 Feb 2024 |
