Well I suspect that most right minded people are aware that Oil will eventually run out (unless you believe its spontaneously created underground by the oil fairy). So have we passed it? Are we close to it? Or is it decades away? What are your thoughts?
As a secondary question, if you believe it has passed or we are close to it, why is there very little media coverage? Are we all in a mass denial?
Peak Oil
Started by StealthProg, Jan 07 2010 04:43 PM
Posted 07 January 2010 - 04:43 PM
Posted 21 September 2010 - 09:39 AM
I think either nobody knows the truth of when peak oil is coming or they're not telling us.
I believe the older technologies do not retrieve all the oil from the reservoir; newer technology can help with the tertiary recovery of this oil. I also believe that geopolitics around the globe & demand (driven by the media, status significance, economics etc) can tamper with the true value of oil.
But I think it's good that people are talking about peak oil, coz it's better for us to be prepare with alternative fuel when it DOES hit. We wouldn't want to have millions of cars put to the junkyard because they're empty
Air Dryer Co2 PeakStarted by Guest_Ranga v_* , 12 Jan 2019 |
Determine Peak Leakage Rate Of Control Valve For Psv SizingStarted by Guest_namvuvu29_* , 24 Jul 2017 |
Peak Thermal Tank Venting Of Water TankStarted by Guest_kowalskidl_* , 09 Mar 2016 |
Flare Stack Sizing Worst Case Peak Flow RateStarted by Guest_hafiz akhtar_* , 16 Apr 2014 |
Peak Flow Rate During De-Pressurization Is Function Of Initial SystemStarted by Guest_Shailes1982_* , 29 Aug 2013 |
