Centrifugal Pumps
#26
Posted 26 January 2010 - 07:50 AM
#27
Posted 27 January 2010 - 02:37 PM
This is Shell formula (see Ankur2061 post) explained in words (without HPD).
Shutoff differential pressure can be estimated as 1.2 or 1.25 x differential pressure at design conditions.
We refer to electric driven process or feeding pumps.
Edited by kkala, 27 January 2010 - 03:03 PM.
#28
Posted 17 February 2010 - 10:44 AM
In many design criteria and practice I found two below formula for estimation of Shut-off pressure of Motor Driven Centrifugal pumps in absence of any Perfoemance Curves:
Shut-off pressure = 1.25 x Diff. Pump Pressure + Design Pressure of Upstram Vessel + Static Press. (From HLL).
Shut-off pressure = 1.25 x Diff. Pump Pressure + Static Press. (From HLL).
I want to know which one of above formula is correct. In this regards, I want to know how those formula is developed.
I appriciate if someone advice me in this regards.
Dear all
hi , i am Ashok
i have a doubt regarding this , pump will reaches it shut off pressure at no flow condition , but at the same time we cant expect the vessel to be at its design pressure. but as worst case we generally go with the equation Shut-off pressure = 1.25 x Diff. Pump Pressure + Design Pressure of Upstram Vessel + Static Press. (From HLL).
can anyone clarify this
i have a scenario, the suction tank (a water tank) is operating at atmospheric pressure. the pump(centrifugal type) and the tank are located at the same elevation (no static head available). now if we do the hydraulic and find the pressure at the suction nozzle it comes less than atmospheric pressure, ie vacuum. whether flow will happen?
Ashok
#29
Posted 17 February 2010 - 12:53 PM
Reverse Flow On Centrifugal CompressorStarted by Guest_Lyne_* , Today, 04:52 AM |
The Centrifugal PumpStarted by Guest_guoyinyanliner_* , 15 Dec 2025 |
Purge Gas For Centrifugal CompressorStarted by Guest_Lyne_* , 19 Oct 2025 |
Centrifugal Compressor TroubleshootingStarted by Guest_sggifrance@gmail.com_* , 14 Sep 2025 |
