Fuel Oil Combustion Flue Gas Quantity
Posted 21 January 2010 - 06:51 AM
I have to calculate flue gas quantity which will be produced during combustion of fuel oil. I have fuel oil LHV, its specification (content of sulphur, nickel, nitrogen, hydrogen,asphaltens, sodium, etc) I know what is air excess air.
Can anybody help me?
Posted 21 January 2010 - 07:26 AM
'Beergson', on 21 Jan 2010 - 12:01 PM, said:
Beergson,
Have a look at the combustion calculation spreadsheet I had posted a long time ago. This should get you started.
Ankur
Posted 21 January 2010 - 10:30 AM
Beergson, the mass of the air and fuel at the inlet of the engine is the same at the outlet, just hotter. That mass is increased by a very little amount of combustion products. The amount of air that goes through the engine in will be equal to the engine displacement x RPM ÷ 2 (assuming this is a four- stroke engine and the combustion is complete).
Posted 24 January 2010 - 11:37 AM
Since you seem to have elementary analysis of fuel oil available, as well as excess air, you can calculate flue gas quantity & composition by stoichiometry. You can neglect CO formation (too little) and consider all C burned to CO2. Combustion calculation spreadsheet by Ankur2061 will be certainly useful.I have to calculate flue gas quantity which will be produced during combustion of fuel oil. I have fuel oil LHV, its specification (content of sulphur, nickel, nitrogen, hydrogen,asphaltens, sodium, etc) I know what is air excess air.
By the way, I would be indebted if somebody could tell me how to locate it in the forum. Whenever I used its search machine for a subject, I failed in finding it.
In case that elementary analysis of fuel oil is not complete, estimates can be made, (see Perry (7th ed), 27-8/11, Liquid fuels), but these concern mainly H content. Perry also presents typical analysis of fuel oils to have an idea. Oxygen content is often not specified, and is not easy to guess.
When content of all other elements (H, S, N, O, ash, etc) has been specified, C content is found by difference.
Posted 24 January 2010 - 11:54 AM
Here is the link for the combustion calculation spreadsheet:
http://www.cheresour...__1
Hope this helps.
Posted 28 January 2010 - 08:16 AM
Beergson,
Ankur
Thank You very much for this spreadsheet
Can You tell me what standard/book solid & liquid fuel calculation has been based at?
THX
Posted 28 January 2010 - 01:58 PM
Beergson,
Ankur
THX
Beergson,
I have not used any standard textbook to generate the spreadsheet. It is just elementary 'Stoichiometry' which you learn from any standard chemistry book & hence I can't give any particular reference. Simply put, I don't need a textbook to do a chemical balance for Carbon, Sulfur & Hydrogen reacting with oxygen. The HHV & LHV are sourced from GPSA databook & that is clearly mentioned in the spreadsheet.
Edited by ankur2061, 28 January 2010 - 01:59 PM.
![]() Fired Heaters/ Burners/ Flue VelocityStarted by Guest_Lyne_* , 15 Mar 2024 |
Smr Reformer Flue Gas FlowStarted by Guest_kaidlut_* , 14 Feb 2025 |
Sugar Impurities After Distilling Ethanol FuelStarted by Guest_vyse_* , 14 Nov 2024 |
Steam Requirement For Mea Reboiler - Co2 Capture From Flue GasesStarted by Guest_liquidcarbonic_* , 25 Sep 2023 |
Flue Gas Stack ModelingStarted by Guest_Maryam sheikhmohamad_* , 28 May 2023 |
