I need some suggestions for what type of heat exchanger to use for vaporizing a stream of ammonia before introduction into a process vessel. Need to generate 1825 lb/hr of ammonia vapor at 60 psig. Feed to exchanger is liquid at ambient temperature and 75 psig at inlet to exhanger. Sat Steam at 300 psig is available for heat.
Is a kettle type shell with a U-tube bundle inserted into it a reasonable design to use, something like a TEMA type AKT? Steam would be in the tubes. Or would another design be better?
Appreciate any comments and suggestions. Thanks.
Liquid Ammonia Vaporizer
Started by Mike B, Feb 02 2010 11:32 AM
No replies to this topic
Posted 02 February 2010 - 11:32 AM
Ammonia Line Vapor GenerationStarted by Guest_simadri_* , 07 Apr 2025 |
