I am filling out a heat exchanger spec. It asks for information about lifting and grounding lugs. But I have no idea what they used for. For my learning value, could anyone please explain to me what they are used for?
Many thanks,
Lift Lugs And Grounding Lugs
Started by Guest_okki_*, Jan 12 2005 04:37 PM
Guest_okki_*
Posted 12 January 2005 - 04:37 PM
Posted 13 January 2005 - 10:40 PM
okki:
Depending on the physical size and ultimate weight of your heat exchanger, you may need Lifting Lugs. I always allow for grounding lugs. Now, lets define what we are discussing:
Lifting Lugs = mechanical devices built in or welded to the equipment for the sole purpose of mechanically lifting the equipment (usually with cables and a crane) for installation or removal purposes. Depending on the type and size of equipment, there may be 2 or more lugs required for safe lifting.
Grounding Lugs = a positively-joined device to a major piece of equipment for the purpose of allowing the equipment to be positively electrically grounded through use of a copper cable to a stable and suited grounding device. This allows the equipment to be grounded and transfers any stray or generated electrical current within the equipment to a safe and convenient ground.
I hope these definitions suffice for your understanding.
Spring, TX
Spring, TX
Guest_Guest_*
Posted 14 January 2005 - 12:54 AM
Thank you very much Art for the valuable education.
Horizontal Pump With Suction LiftStarted by Guest_Deep24_* , 02 Aug 2024 |
Fluid Of Gas Lift In Enhanced Oil RecoveryStarted by Guest_Poet_* , 09 Aug 2019 |
Seawater Lift Pumps - Location Of Restriction OrificesStarted by Guest_andybud_* , 10 Apr 2019 |
Sizing Of An Electric Gas Heater (Gas Lift Heater)Started by Guest_Fiscopet_* , 05 Apr 2019 |
Choke Valve In Gas Lift OperationStarted by Guest_inkar_* , 17 Nov 2018 |
