where can I get densities of methane at 25 bar and 1000K?
Methane Densities At High T & P
Started by bmont, Feb 19 2010 10:49 AM
Posted 19 February 2010 - 10:49 AM
Posted 19 February 2010 - 11:53 AM
bmont,
The density at the 25 bar isobar at some values of temperature are as below:
500K - 9.648 kg/m3
520K - 9.266 kg/m3
540K - 8.914 kg/m3
560K - 8.588 kg/m3
580K - 8.286 kg/m3
600K - 8.005 kg/m3
I don't think extrapolating upto 1000K will work.
The above values are from:
"Thermpophysical Properties of Fluids. II. Methane, Ethane, Propane, IsoButane & Normal Butane" by B. A. Younglove & J.F. Ely of Thermophysics Division, National Engineering Laboratory, National Bureau of Standards, Boulder, Colorado 80303.
Hope this helps.
Posted 19 February 2010 - 02:13 PM
You can use the corresponding states theory. Critican conditions for CH4 are 190.564 0K & 45.9 Bara (Zc=0.286). So Pr=0.545 & Tr=5.25, which give about Z=1.0 in a Compressibility factor diagram (mine is from Hougen, Watson, Ragatz, 1955, Zc=0.27). So density under mentioned conditions ρ=(16.043/22.414)*(25/1.01325)*(273.15/1000)/1.0=4.8 kg/m3.where can I get densities of methane at 25 bar and 1000K?
For 600 0K Z is found again about 1.0, so ρ=8.04 kg/m3, versus 8.005 kg/m3 reported by Ankur.
Actually corresponding states indicate that CH4 of 25 bara behaves as ideal gas at such high temperatures as 1000 oK.
Posted 21 February 2010 - 07:39 PM
I run PRO-II simulation using PR EOS, the answer is 4.795 kg/m3 which is very close to the one mentioned aboveYou can use the corresponding states theory. Critican conditions for CH4 are 190.564 0K & 45.9 Bara (Zc=0.286). So Pr=0.545 & Tr=5.25, which give about Z=1.0 in a Compressibility factor diagram (mine is from Hougen, Watson, Ragatz, 1955, Zc=0.27). So density under mentioned conditions ρ=(16.043/22.414)*(25/1.01325)*(273.15/1000)/1.0=4.8 kg/m3.
Flow Switch High RangeStarted by Guest_Lyne_* , 11 Apr 2024 |
High Pressure Condensate Recovery To Low Pressure DeaeratorStarted by Guest_hd_1982_* , 16 Feb 2024 |
Washwater Injection To Hydrocarbon Stream At High Temperature And PresStarted by Guest_Venkat @89_* , 17 Sep 2023 |
High Temperature Water Gas Shift ReactorStarted by Guest_Nur8_* , 18 Feb 2019 |
Psychrometric Chart: High Dry Bulb, Low RhStarted by Guest_elliot.433_* , 13 Jul 2023 |
