Roughness Factor And P-Drop In Twisted Pipe
#1 moverduin
moverduin
  • 4 posts
Posted 24 February 2010 - 11:28 AM
Air flows through a pipe at 270 CFM with inlet temp of 30 F, and pressure of 105 psi. The pipe is copper, 1 ft in length and 1 inch in diameter. The copper pipe is twisted in a helical manner. Height of each twist is approximately 1/5 inch.
How would you calculate pressure drop? roughness factor?
thanks!
#2 sheiko
sheiko
  • 732 posts
Posted 24 February 2010 - 01:15 PM
A hint: absolute roughness is not calculated. It is a data you can find in various handbook such as Perry.
Now you can do your homework.
#3 demank
demank
  • 150 posts
Posted 24 February 2010 - 09:49 PM
thanks!
There are 2 points that you must consider before calculating pressure drop:
1. moody friction factor, use a chart or equation (exist in many book)
2. Helical shape. Do you dare to ignore the Equivalent Length (elbow, fitting, valve, etc have this equivalent length) of this helical shape? (regarding it just a shor pipe 1 ft).
