How Do You Calculate The Firetube Length In A Waterbath Heater
#1 lookingtolearn
lookingtolearn
  • 3 posts
Posted 25 February 2010 - 06:36 AM
I have seen the following equation, but I question the source:
L = 0.00038*Q/D
L - length
Q - capacity, (Btu/hr)
D - diameter, (inches)
If you have a graph that shows how the efficiency changes based on the firetube length and heat input, that will be helpful too.
There is no tube bundle or heat exchanger involved.
Thank you!
#2 Root
Root
  • 293 posts
Posted 27 February 2010 - 10:22 AM
To find out the Tube length and diameter you need to calculate:
Q=UA (T2-T1)
From this equation, once you calculate the A then you can calculate the tube length and dia.
Hope you will get it.
Cheers
Toor
#3 lookingtolearn
lookingtolearn
  • 3 posts
Posted 08 March 2010 - 09:52 PM
Thanks Toor!
Question:
Q = capacity
delta T = temp change
A = area
U = ???
#4 Qalander (Chem)
Qalander (Chem)
  • 829 posts
Posted 08 March 2010 - 11:23 PM
Dear
U = Heat Transfer coefficient i.e. relates to the property of material/system involved.
#5 djack77494
djack77494
  • 1,282 posts
Posted 21 May 2010 - 01:35 PM
LTL,
Your original equation,
L = 0.00038*Q/D
looks to be a design equation that is based on limiting the heat flux through the surface area of the tube. The other equations suggested to you are entirely different; they are the basic heat transfer performance equations.
Doug
#6 Propacket
Propacket
  • 260 posts
Posted 19 July 2010 - 12:08 AM
lookingtolearn,
djack77494 is right. Your equation is dedicated solely for sizing of the fire tubes based on 10,000 Btu/hr.ft2 heat flux. You can find it in the following book:
Surface Production Operations, Volume 2, 2nd edition
By: Ken Arnold & Maurice Stewart
However, this book does not explain how the equation has been derived.
If you have calculated the fire tube diameter, you can also calculate the length of fire tube using this simple formula:
Surface Area (ft2) =Heat Duty (Btu/hr)/Heat Flux (Btu/hr.ft2)
Surface Area (ft2) = pi x diameter (ft)*length (ft)
Length (ft) =Surface Area (ft2)/ (pi x diameter (ft))
You will find that for 10,000 Btu/hr.ft2 heat flux, length calculated by the above equation will be fairly in agreement with your design equation.
