Modulating Pilot Valves - When To Use
Started by Bill B, Mar 02 2010 06:42 PM
Posted 02 March 2010 - 06:42 PM
When is it appropriate to consider a modulating valve, vs. a non-modulating pilot valve? I have two vendors - one recommending the modulating, the other vendor not. Thanks in advance, bill
Posted 03 March 2010 - 01:43 AM
A modulating Pilot operated PSV has some advantages viz, the inlet and outlet laterals can be sized for the required flow, rather than for the rated flow.
I suspect this comes at the expense of reliability as compared to pop-acting, but I do not have the reliability data to back this statement.
If required, I normally recomend a modulating, non-flowing type pilot operated PSV, specially if the pilot is remote.
Posted 03 March 2010 - 03:35 AM
Bill B,
Could you be more specific by providing the details of the application where you need a pilot operated relief valve. The above details are too insufficient to provide a meaningful answer.
However, you can look up the following link to get an overview of pilot-operated relief valve:
http://en.wikipedia....ed_relief_valve
Hope to get more details from you.
Posted 03 March 2010 - 06:46 AM
As a general response,when operating pressure is much close to design (set) pressure.
Posted 12 March 2010 - 12:51 PM
Thanks for the input. My question was mainly a general one. Ankur, I am presently looking at two cases. In the first, we are protecting against blocked flow from a compressor (process air). The back pressure is high and I will replace the existing conventional valve with either a bellows or pilot. One down the road issue is that process pressure may be raised to closer to the set point.
In the other case same issue with back pressure - syn gas vapor stream. In this case there is some possibility of mild deposition of material.
One of our reps sent me quotes for both bellows and non-modulating pilots. Another gave quotes for modulating pilot valves. I was basically looking for a checklist of things to consider when making the bellows vs. non-modulating pilot vs. modulating.
Thanks again. Bill
Thanks again. Bill
Parallel Control Valves Downstream Relief ScenarioStarted by Guest_pklavinsJ_* , 18 Jun 2025 |
![]() Breather Valves - Liquid Movement In Breathing ScenarioStarted by Guest_panoska_* , 14 Dec 2024 |
![]() Isolation Requirement For Bypass Valves/ Movs.Started by Guest_shantanu.ghag_* , 15 Sep 2024 |
![]() Pressure Regulators Vs Control ValvesStarted by Guest_panoska_* , 19 Jun 2024 |
![]() Valves On Low Pressure Steam ServiceStarted by Guest_Ali4269278331_* , 15 Apr 2024 |
