Styrene Monomer/inhibitor Separation
Posted 05 March 2010 - 11:02 AM
The styrene should be purified by extracting twice with 10% sodium hydroxide to remove the monomethyl hydroquinone (MEHQ) inhibitor, washing three times with distilled water, drying over a calcium hydride, and distilling under reduced pressure using a nitrogen ebullator (b.p. 820/100 mm.Hg).
So i was wondering if you think that this method can be applied for 4-tert-butylcatechol as well? I also want to know what if i skip the distillation step, which materials i will separate in distillation because the purity of styrene i'm using is 99.9%
Thanks in advance
Posted 05 March 2010 - 07:30 PM
I used to work in a styrene monomer manufacturing facility but I am a little less knowledgable on downstream polystyrene plants.
A few points I can make on SM inhibitors:
1. TBC inhibitor is normal temperature use and shelf life improvement of the SM. It needs a little O2 to be present to be effective.
2. Some plants to make various styrene based polymers do not remove the inhibitor or pretreat the SM. It goes stright into the reactor as received. I guess in these case the reactor is heated therefore overcoming the inhibition.
3. When purifying the SM in the distillation area of a plant we would use high temperature inhibitors. If you wish to distill SM or mixtures of it, vacuum is normally used so that the distillation temperature can be kept below 100dC. You still need the high temp inhibitors but less of it. The higher the temperature the more styrene tars are produced (tary, black long chain molecules, even polymer), which end up being a waste stream from distillation bottoms. Common modern high temp inhibitors are DNBP for example (di nitro butyl phenol).
3. I haven't heard of MEHQ.
4. I'm trying to find out from a friend how TBC is removed when that is necessary. If I find out I'll make another post.
Dazzler
Posted 06 March 2010 - 12:55 AM
Posted 06 March 2010 - 06:35 AM
Further to my earlier message:
I saw that friend I mentioned at a housewarming party tonight. He says for some polystyrene polymerisation plants the TBC is removed or neutralised by contact with alumina balls in twin (duplex) vessels. Then downstream there is a filter to perhaps catch any alumina fines. The Alumina concept seems the same as mentioned on the weblink provided by Breizh.
Dazzler
Posted 08 March 2010 - 03:47 AM
I will give it a try.
Posted 18 May 2010 - 11:09 AM
I am also doing removal of 4-t-butyl catechol. I wonder if you succeeded by using the sodium hydroxide and water?
Please let me know.
Thanks.
Posted 01 November 2010 - 01:47 PM
Hi Jooniore,
On laboratory scale styrene monomer purification, styrene monomer was washed with two equal volumes of 5% (or 10%) aqueous sodium hydroxide to remove the inhibitor (t-butyl catechol, TBC).The inhibitor free styrene was washed with four equal volumes of water to make sure it was nutralize (check by litmus) , dried over anhydrous magnesium sulfate.
If you start with styrene monomer which have contaminate more than you need in the final (contaminate such as benzene, toluene and ethylbenzene). Additional step needed. Styrene free TBC from above step should be distilled under nitrogen through a 20 inch Vigreaux column at reduced pressure (31oC., 5 mmHg.). A middle fraction boiling over a 0.2o range was collected, stored under nitrogen in a refrigerator, and used within three days.
I hope this can help you
Edited by Chanwit S., 01 November 2010 - 10:46 PM.
Posted 15 April 2011 - 09:33 PM
Posted 16 April 2011 - 02:03 AM
Did you try google ? (list of producers in the US)
http://www.atsdr.cdc...les/tp53-c5.pdf
When I was involved in the production of latex , Styrene monomer was inhibited using TCB , other monomers were inhibited using HQ .
Hope this helps
Posted 21 April 2011 - 07:33 AM
Air Separation Plant DesignStarted by Guest_adda_* , 03 Mar 2026 |
Acidic Condensate In Sulphate Recovery By Vapour SeparationStarted by Guest_Ranga v_* , 09 Nov 2025 |
Design Of Direct Contact After Cooler (Dcac) For Air Separation UnitStarted by Guest_Paulogeorge_* , 29 Jul 2025 |
Separation Technology For Separate / Distillate Hcl From Water MixtureStarted by Guest_dpunnn_* , 11 Sep 2024 |
