Upper And Lower Flammable Limits
Started by Guest_george_morton_*, Jan 30 2005 01:14 PM
Posted 30 January 2005 - 01:14 PM
Hi, how are upper and lower flammable limits of a mixture calculated when given upper and lower flammable limits of pure components in vv % Any reference or subtle hint would be most welcome thank you.
Posted 30 January 2005 - 04:44 PM
http://www.gexcon.co.../GEXHBchap4.htm
This is the Gas Explosion Handbook. Look for Le Chatelier's Law. This law can be used both to estimate LFL and UFL.
Posted 31 January 2005 - 03:23 PM
George Morten:
As a supplement to the response you got from Gvdlans:
For a mixture of combustible gases, you can use Le Chatelier's relationship:
Lm = 1 / SUM ( Xi / Li )
Where:
Lm = LFL of mixture
Xi = mol fraction (or volume fraction) of each component gas in the
combustible gas mixture
Li = LFL of each component gas in the combustible gas mixture
Please note:
(1) The same relationship can be used to calculate the UFL of a mixture of
combustible gases.
(2) Lower and Upper Flammability Limits (also known as Lower and Upper
Explosive Limits) apply only to gases or vapors.
(3) You will find it very useful to read web.umr.edu/~dludlow/classes/che258/Flammability.ppt
Where:
Lm = LFL of mixture
Please note:
combustible gases.
Posted 01 February 2005 - 04:36 AM
I just want to add that the temperature corrections shown in web.umr.edu/~dludlow/classes/che258/Flammability.ppt are not correct. They should be:
LFLT=LFL25-0.75(T-25)/Hc
UFLT=UFL25+0.75(T-25)/Hc
Reference is made to Zabetakis M.G.; Flammability Characteristics of Combustible Gases and Vapors Bulletin 627, Bureau of Mines, Washington (1965). Equations (33) and (36) on pages 22 and 23.
Pressure Relief Atm Dispersion Of Flammable/toxic Gases - Mist FormatiStarted by Guest_Xenolithian_* , 22 Nov 2023 |
Control Limits And Key Performance Indicators (Kpis)Started by Guest_CHEMSTRONG_* , 13 Aug 2022 |
Asme Sec Viii Blowdown LimitsStarted by Guest_SawsanAli311_* , 28 Mar 2020 |
Horizontal Discharge Of Flammable VaporStarted by Guest_dozerboy_* , 24 Mar 2020 |
Api 526 Psv Flange Ratings And Pressure LimitsStarted by Guest_SawsanAli311_* , 22 May 2019 |
