Lpg Booster Pumps
Posted 08 March 2010 - 10:19 AM
Could you explant why the booster pumps are used in addition to the main pumps in LPG pipeline transport, while they are not requiered in truck/ship loading ?
is there a relation between the head and the NPSH required of a pump?
Posted 08 March 2010 - 11:35 AM
There is relationship between NPSHr and pump flow, suction head requirement increases with increased flow. You can see that on any pump manufacturer curve.
http://www.irrigatio...t.com/npshr.htm
http://www.pumped101.com/npsh.pdf
http://www.cheresour...galpumps4.shtml
Posted 08 March 2010 - 01:06 PM
Usual diagrams (head < 200 ft) for single impeller pumps show (statistical) relation between pump flow rate and NPSH (increases with flow), but no dependence on head. Flow rate mainly affects NPSH; impeller type (and craftsmanship to some extent) can reduce NPSH for a pump of given flow & head, yet impeller type is usually use-defined, e.g. process pumps have a rather narrow range of suction specific speeds.Could you explain why the booster pumps are used in addition to the main pumps in LPG pipeline transport, while they are not required in truck/ship loading ?
Multistage pumps can develop heads to 2000 ft and probably require higher NPSH than a single stage pump of same flow rate due to complexity. However I have not found any written evidence on this (advice is welcomed!).
I believe booster pumps are used to: (1) supply additional head to an existing pump (2) supply enough pressure for NPSH to the suction of main pump, if above "assumption" is true (some non centrifugal piston pumps need a rather high suction pressure to operate). In case of LPG transfer main centrifugal pump is most probably multistage, versus a single stage booster (or of few stages).
You do not clarify whether same LPG main pump is used for both pipeline transfer and truck / ship loading. If so, check (1) in case of pipeline transfer (flow rate may not meet requirement without the booster pump). Case (2) is rather improbable.
Edited by kkala, 08 March 2010 - 04:43 PM.
Posted 09 March 2010 - 10:51 AM
I guess we chare the same thoughts that NPSH of pumps with High heads is somewhat greater thant that of low head
I have an exemple on my own where : LPG Main Pump (Head = 700m, NPSHr = 7m)
LPG Booster Pump (Head = 75m, NPSHr = 3m)
but it still not enough to confirm what we said.
Again, I have another question
when using two pumps in series, Technicaly, How to select the discharge pressure of the first pump
exemple
Suction 1st pump 10barg
Discharge 2nd pump 30barg
which will be better? Discharge 1st pump 15barg or 20barg...
Posted 10 March 2010 - 02:33 AM
Posted 10 March 2010 - 11:34 AM
I have asked local advice (Athens) on the NPSH requirement of multistage centrifugal pumps, without a clear answer.
Another case needing booster pump is when distance between tank and pump is too long. A long suction would result in low available NPSH due to friction, flow may be even cut off in case of big ground ups / downs. So a booster pump is necessary to keep flow or to regain suction pressure drop. It is noted that there may be truck loading pumps 1-2 km far from their tank in a refinery.
Edited by Art Montemayor, 07 August 2010 - 08:26 AM.
Posted 29 June 2010 - 04:32 AM
Truckload carriers
![]() Centrifugal PumpsStarted by Guest_panoska_* , 01 Feb 2025 |
![]() Selection Of Type Of Pumps For "negative" Npsha And Solution TStarted by Guest_linda_pro_* , 29 May 2024 |
Booster PumpStarted by Guest_Ananthakumar A_* , 03 Jan 2024 |
Vibration Of The Pump (Reciprocating Pumps / Plunger Pumps)Started by Guest_vsedhuraman_* , 06 Oct 2023 |
Variable Speed Pumps Operation.Started by Guest_panoska_* , 11 Oct 2022 |
