please i need some help, I have to design a steam ejector and i don"t have any idea how to began, if do you have something that could help please.
inlet temprature : 107°C, flow rate 2 t/h
outlet temprature: 135°C , flow rate 2 t/h
Posted 12 May 2013 - 08:24 AM
Posted 12 May 2013 - 10:38 AM
houss123,
You don't design a steam ejector. You only provide the process data to a steam ejector manufacturer. It is the manufacturer who designs, fabricates, delivers and provides performance guarantees for the steam ejector. This has been discussed numerous times on the forum. If you use the search feature of the forum you will find dozens of posts related to steam ejectors on "Cheresources". Some links for steam ejector related posts are provided below:
http://www.cheresour...-steam-ejector/
http://www.cheresour...booster-system/
http://www.cheresour...or-calculation/
http://www.cheresour.../17619-ejector/
http://www.cheresour...certain-vacuum/
http://www.cheresour...steam-pressure/
Posted 13 May 2013 - 10:45 AM
thank you Mr.Ankour
Posted 23 May 2013 - 06:45 AM
Edited by Shivshankar, 23 May 2013 - 06:48 AM.
Steam Carrying Liquid From The Sour Water Stripping TowerStarted by Guest_kaidlut_* , 12 Sep 2024 |
