as said by fseipel TVP (true vapor pressure) shows the bubble point pressure at specified temperature,
RVP (Reid vapor pressure) shows values which are easier(compared to TVP) to measure (with instruments),
(you may consider a textbook as Charaterization and properties of petroleum fractions for the difference between True and Reid vapor pressure)
With a simulator TVP and RVP are calculated from mixture composition generated with characterization
and the accuracy of calculated values depend from that.
Generally a software should calculate different values for RVP and TVP but that depends from included procedure.
In your case once the mixture composition has been defined
a simulator (these utilities are avilable in almost all petrochemical simulators) should be able
to calculate bubble point temperature (given a pressure)
or bubble point pressure (given a temperature),
from your comment it seems that you are calculating bubble point temperature (given the operating pressure),
and the calculated value (calculated 100 F vs. operating 72 F) shows that you are
below bubble point temperature (stabilized liquid phase) which is correct.
Is that true ?
Edited by PaoloPemi, 20 August 2013 - 02:36 AM.
