Nozzle Sizing Calculation
nozzle id nozzle calculation nozzle design
32 replies to this topic
#26 astro
astro
  • 124 posts
Posted 15 June 2024 - 11:32 PM
Another very useful point of reference are the series of papers by Mark Bothamley:
https://www.markboth...com/?page_id=99
Quantifying Gas/Liquid Separation Performance, Parts 1, 2 and 3
Various inlet device type ρν² criteria are listed in Table 4 of Part 1 that are roughly similar to the data listed in GPSA as per comments above at:
https://www.cheresou...ation/?p=127311
#27 astro
astro
  • 124 posts
Posted 15 June 2024 - 11:57 PM
Greetings everyone. Can anyone explain to me the physical significance of "Density x Velocity^2" term? What does it actually mean and what is it called? Few places it is referred as momentum flux, is there any other term for it? Thank you for your time.
Afaruque,
On youtube, search for Momentum flux equation with application.
This tutorial should help you.
Excellent tip Breizh - I find the loose use of "momentum" confusing because I can't help apply undergrad dimensional analysis and the term simply doesn't stack up when I apply basic arithmetic.
"Momentum flux" makes dimensional sense and is consistent with the theory you point to (the tutorial from Djordje Romanic was a handy refresher).
GPSA uses "velocity head" for momentum flux that is also equivalent to "dynamic pressure", as noted by Bothamley.
#28 Anastasia1905
Anastasia1905
  • 4 posts
Posted 08 July 2025 - 05:21 AM
Hi everyone!
I am currently calculating the maximum capacity of the separation equipment and the following problem has arisen: my calculation of the outlet liquid velocity is higher than the vendor calculated.
I use the following formula: Vout = Act.Vol.Flow (m3/h)/3600/(Pi*Dnozzle^2/4).
Is my formula correct?
Thanks in advance!
#29 breizh
  • 7,066 posts
Posted 08 July 2025 - 05:47 AM
To me no question about the formula, V (m/s)= Qv(m3/s) / S (m2)  ,
Make sure you use the same volumetric flow which is coming from the mass balance , Qv = Mass liquid / Ro liquid ,Mass liquid =Total mass-Mass gas.
My 2 cents
#30 latexman
  • 1,937 posts
Posted 08 July 2025 - 05:48 AM
It looks right to me.  Volumetric flow/area = velocity.
#31 nguyen_uptorcem
nguyen_uptorcem
Posted 24 September 2025 - 11:20 AM
Hi everyone,
I’m working on a small revamp of our condensate degasser and would really value your advice on the inlet arrangement.
  • Current setup: submerged inlet, no device; feed GVF ≈ 7%.
  • With the new flow, the inlet momentum is about 2,900 Pa (ρv²), which is above the no-device limit in API 12J (~1,000 Pa).
  • A vane-type inlet (Schoepentoeter) won’t work here because the inlet is submerged, and we can’t change the nozzle size or lower the liquid level (the nozzle is close to the bottom).
Could you kindly suggest submerged, low-shear solutions that would meet the API 12J momentum requirement?
Thanks so much for your guidance!
#32 astro
astro
  • 124 posts
Posted 01 October 2025 - 09:52 PM
Hi everyone!
Thanks in advance!
Just be clear on the distinction of superficial velocity that's relevant to 2 phase mixtures. Assuming that the fluid stream you're referring to is effectively all liquid, then refer the other posts and their commentary.
Also, I'd suggest you make sure that you're clear on velocity in terms of gas entrainment. A typical approach is to assess Froude number (think of the vortex formed as bath water drains out from the tub). The reference that I refer to in this regard is the work by Rochelle & Briscoe, Predict and Prevent Air Entrainment in Draining Tanks , Chemical Engineering, Nov 2010, Vol. 117, Iss. 12, pp.37-44.
They do a deep dive on various design criteria using this theory put forward by other workers and present a meta-analysis, plus a discussion on practical application of vortex breakers.
Bothamley, referred to a couple of posts back is also worth a read on this subject. You could also consult API RP 12J 9th ed. for guidance, as well.
Edited by astro, 01 October 2025 - 10:48 PM.
#33 astro
astro
  • 124 posts
Posted 01 October 2025 - 10:47 PM
Hi everyone,
From what I can glean from sources available to me relating to G/L/L separators, use of a bottom entry inlet is satisfactory if the GVF is "negligible" when applied to a horizontal vessel (you haven't specified orientation, refer API RP 12J 9th Ed., Annex A). If your separator is vertical then I think I'd struggle to source references to assist with an empirical guideline design approach that considers a submerged inlet basis. As I'm sure you've discovered, the standard approach is to design the inlet above the liquid pool to promote separation of gas from the liquid as it falls.
I'm also not unequivocally clear on what fluid "condensate" means for you. Is this steam or hydrocarbon condensate? I'm assuming the latter because you're referring to API RP 12J. In which case, you have a need to address liquid-liquid separation. For this reason, I'm also assuming that the vessel is horizontal, given that this is the typical orientation of L/L service.
I'd suggest that a GVF of 7%, using conservative judgement, is small but significant. Your design will need to provide a sufficiently long (assuming horizontal orientation) inlet compartment to allow the liquids to degas. As this is happening, the (one or two?) liquid phases are undergoing mixing as the bubbles rise through the liquid volume. This could create foaming, which will complicate matters if your liquid exhibits this type of behaviour.
Once you confirm the key details noted above (but assuming that my assumptions hold), I would suggest consulting a vendor with in-depth history in the area of gas/liquid and gas/liquid/liquid who offer various inlet device types, who may be able to offer better guidance with field experience to support their advice. Use standard commercial acumen and due diligence but if I were you, I'd put a company like Sulzer on the inquiry list because they're one supplier that has the sort of technical depth that I'm thinking of (FWIW I've got no commercial affiliation with any equipment vendor).
Given that you're dealing with a brownfield application constrained as advised, I wouldn't be surprised if you'll need to employ CFD to gain sufficient assurance that the design envelope that you're addressing can be processed by the separator and whatever modifications you make to it.
Edited by astro, 02 October 2025 - 09:00 AM.
