How to calculate the air conumption rate when pressure drop of storage vessel and volume of storage vessel known.
Thank yu
Posted 10 November 2013 - 12:45 AM
Thank yu
Posted 10 November 2013 - 01:01 AM
If I understand correctly your query .
firstly : From the well known relation : P*V= Z*R*T >>> Ro (T,P) = Mw/ V= Mw*P/(Z*R*T) in proper units
From the initial Pressure , let say P0 ,you can calculate the mass Mo inside the vessel : M0 = Vtank * Ro ( density air at P0 , T0)
Do the same for the final pressure ,Pf >>> Mf =Vtank *Rf (Pf,Tf)
(M0-Mf) / ( tf -t0) = flow rate kg/s
Hope this helps
Edited by breizh, 10 November 2013 - 01:03 AM.
Posted 10 November 2013 - 01:20 AM
Hi Breizh,
Is the "tf & t0" time factor?
Thank you Breizh
Edited by teesan, 10 November 2013 - 02:17 AM.
Posted 10 November 2013 - 01:52 AM
yes , tf = time to reach Pf ,
Posted 10 November 2013 - 02:02 AM
Thank you breizh
Maintenance And Power ConsumptionStarted by Guest_Lyne_* , 04 May 2024 |
Rate Of Heat Transfer Vs VelocityStarted by Guest_golegolegole_* , 30 Apr 2024 |
Ammonia Evaporation Rate InquiryStarted by Guest_aslungaard_* , 30 Mar 2024 |
Air Consumption For On Off ValvesStarted by Guest_itsmetinnie_* , 11 Mar 2024 |
Duplication Of Psv And Flow Rate For Exchanger Tube Rupture ScenarioStarted by Guest_Platonicus_* , 11 Mar 2024 |
