Here are my questions:
1. Why is the separation carried out in a double column (i.e. low and high pressure column)? Why can't it be carried out in a single column, i.e. low pressure column?
2.How is the 'suitable' tray for crude argon feed decided?
3. Why is it necessary to withdraw a waste gas stream?
Below are my answers to your 3 questions:
1. The HP column is just a stripping Column, where Oxygen will be stripped and can be collected at the bottom with an average Composition of 30 %, which normally is abbreviated as RL (Rich Liquid ), provided that you have a Liquid nitrogen reflux, which happens in a Simple Nitrogen generator, where a Column is aided with a total condenser. But when you aspire for Oxygen of purity of 99 % and above, you have to opt for Two columns. PL (Poor Liquid) and Rich Liquid (RL) serve as reflux and feed to LP Column in addition to LP Air ex an Expansion turbine (Only for the Lachmann Air cycle, not for the Claude cycle). Here, the incoming RL is vaporized against the condensing GAN (Gaseous Nitrogen). As the vapor starts moving up the column, PL as well as RL start stripping the Oxygen in the upcoming vapor, and as a result the vapor becomes rich in N2 and the sump Liquid rich in O2. There is an energy integration process working where the re-boiler and condenser load are balancing each other and perhaps this explains the requirement of Double Column, primarily to produce Liquid N2 reflux to be used in both columns, while in HP column it will strip O2 from incoming air, in LP column it provides the necessary rectification for upcoming vapor. The reason for operating the Column at different pressure is N2 at atmospheric pressure is colder than O2, so at elevated pressure it becomes warm enough to release enough heat for the RL to boil.
2. Argon take off is generally governed through studying the Column profile. The point of take is generally 10 % argon content. As higher you go, the Argon percent might increase, but at the cost of N2 % increase, which might cause N2 binding in Crude and Pure Argon Column, so the desirable take off point is 10 %.
3. As per product spec, LP Column delivers GAN, GOX and LOX, which are much higher than the generated RL vapor, so if you don't withdraw that extra amount, the LP Column pressure will increase as a result of the saturation temperature of Pure GAN and LOX, which will result in imbalance. So it must be withdrawn. It does serve another purpose for the regeneration of Pre Purification Units.
Bodhisatya.
