i need to design a coagulant and a flocculant tank in a treatment of produced water before a flotation unit (DGF)
Design Of Coagulant And Floculant Tank
Posted 22 April 2014 - 04:25 PM
Posted 22 April 2014 - 06:24 PM
Mariemm,
Consider to ask support from Vendors , they know their products and what will be the best process conditions after performing Tests ( Jar test). They will tell you how is the material ( solid, liquid form) , what is the equipment needed based on consumption and concentration (size) , the type of mixing , the pump ,etc
Edited by breizh, 23 April 2014 - 03:43 AM.
Posted 23 April 2014 - 08:27 AM
in fact i need to design the coagulant and flocculant tanks ( length , heigth , diametr and capacity ) as well as the dose and flow rates of chemical injection .I've found some equations but it wasn't helpfull
some of equations are :
D =Q*X/d where D the total injection flow , X is the optimum dose ( 35 ppm of a coagulant and a 5 ppm of the flocculant) that's all
i need some documentation ( sheet or a standard ...)
Posted 23 April 2014 - 11:08 PM
Mariemm ,
Your equation is weird !
Just do a mass balance , of course you need input like property of the solution ( g active mater/liter) , quantity to be injected (kg/h) , the quantity you want to keep (minimum stock) , How often do you want to do replenishment ? this will give you an estimate of the size ,
some L/D standard for your tank then play around to get the best design to install agitator , Sensor , overflow ,....
Hope this helps
Tank Blanketing With Natural Gas/ Vapor Recovery SystemStarted by Guest_MethanolPlant_* , Today, 08:17 AM |
Design And Fabrication Of Reflux DrumStarted by Guest_Femi_* , 22 Apr 2024 |
Jt Based Hcdp Design V/s Mechanical Refrigeration Hcdp Unit.Started by Guest_BabRafiq1_* , 19 Apr 2024 |
