I currently have a problem related to heat exchange (which I do not deal with it on daily basis). We have a steel pipe through which hot gas flows. The pipe does not have any insulation. The outside air can be considered as stagnant at 25 deg C. Initially I applied the equation mentioned in following thread. But it gave me unreasonably high heat loss.
http://www.cheresour...insulated-pipe/
So I searched more and found that I may need to use "Overall heat transfer coefficient" and at this point I got confused. Can somebody provide me calculation steps(or equations) and coefficient values in my case? Do I have to use convection heat coefficient on either side of pipe material?
Below are details:
- Hot air flowing through a steel pipe.
- Hot air temp = 420 C
- Pipe Dia = 127mm
- Pipe wall thickness = 1.5 mm
- Pipe Length = 42 inches (1066mm)
- Pipe Material = steel(carbon steel)
- Outside air temp = 25 C
- Outside air = stagnant
Any help would be appreciated.
