Capillary And Water Drops Diameter
#1 Engineer in making
Engineer in making
Posted 11 October 2014 - 07:34 PM
Hi, I'm Working on Dynamic Fluids homework that wants me to explain the relationship between The capillary
and water drops diameter when are on contact like in the picture shown. Now I know that the smaller the
diameter of the drop, the faster the capillary is able absorb the drop. Thus, the level water should be higher the
smaller the drop's diameter is. However, I don't really know how to prove this using fluids equations. Should I
use Bond Number to prove this or in terms of surface tension where (σπDc cos(θ) = ρgV) ?
  • 6,349 posts
Posted 12 October 2014 - 01:24 AM
this may help you ,Jurin's law :http://farside.ph.ut...tml/node49.html
good luck.
Edited by breizh, 12 October 2014 - 01:26 AM.
