Dear friends
For calculating the shutt of pressure
We we have pump curve
Pump end of curve quantity ftom H Q diagram +suction pressure
My question is
In some design i see theu consider the suction vessrl design pressure instead of suction pressure .
My second question
As you know in pump curve we have 3impeller
Dose it need to calculate the shutt of pressure with max impeller. Or normal impeller is ok
Pump Shutt Of Pressure
Started by m42364236k, Oct 20 2014 10:19 AM
Posted 20 October 2014 - 10:19 AM
Turbine Driven PumpStarted by Guest_Rahimzadeh_* , 27 Apr 2024 |
Vacuum Pump Power EquationStarted by Guest_hysyshunter_* , 22 Apr 2024 |
