I want to know how to size warm up line of steam turbine?
Posted 29 November 2014 - 01:03 AM
Posted 29 November 2014 - 02:46 AM
Hi Zahra,
In general a steam turbine, especially larger units, should be warmed gradually by recommended (normally vendor recommendation) warm up ramps rate; then relevant line would be sized accordingly. But typical size of warm up line is one inch...
Posted 29 November 2014 - 04:09 AM
Dear Mr. Fallah
there is a steam turbine with HPS inlet line 8".
is not 1" line for warm up of HPS line (8") small?
Best Regards
Posted 29 November 2014 - 05:15 AM
Dear Zahra,
When we see that the ramp rate for warm up of the steam turbine to bring it to operating temperature is in order of magnitude of "Degrees Celcius/hr", then appears a 1" line couldn't be so small for such operation in a steam turbine with inlet line of 8". In most cases mentioned line is included a globe valve to allow for adjusting the recommended ramp rate...
Flash Steam Vessel SizingStarted by Guest_JohnFields343_* , 24 Apr 2024 |
Steam AccumulatorStarted by Guest_Valeriacortez11_* , 15 Apr 2024 |
Answered
Steam Pressure Requirements For Limpet Batch ReactorStarted by Guest_golegolegole_* , 10 Apr 2024 |
Barometric Legs Line SizingStarted by Guest_panagiotis_* , 17 Mar 2023 |
