The situation as follows:
I have two storage tank. Tank A is 2m elevated above ground level. Tank B is on the ground with inlet nozzle is 0.5m above ground.Tank B is being fed by Tank A with flowrate of 10m3/d.
The outlet piping from Tank A is vertical pipe from bottom of tank and bend into horizontal pipe respectively (like an L shape). The length of vertical pipe is 2m and horizontal part is 10m.
The question is,
1) at given flowrate, what is the time taken for liquid to flow from Tank A to Tank B?
2) what happen if the elevation of Tank A is being lowered down to 0.5m? Is time taken to reach tank B is longer?
What happen here, I'm not sure whether the time taken shall be rely fully on the velocity or any other consideration?
